Am I being unreasonable or is Harley?
Old Jul 27, 2022 | 08:11 PM
  #51
wombat457's Avatar
wombat457
@MattLS6
Correct me if I am wrong but you said that this happens roughly every couple of hundred miles ..... that tells me that whatever the problem is, it is taking that many miles for it to fail - yeah I know, obvious. I had a car back in Oz that would NOT start after being run for any length of time. Give it an hour and away it would go again ........ the issue turned out to be a distributor problem and a problem that was being caused by "heat". Once the car cooled down, all was good till it ran back up to temp.
I am thinking that your issue may be similar - something heating up - like a coil - but taking 200 miles to fail or begin to fail.
Will shoot you a PM re something else that I would suggest, but don't want to inflame people here over
Old Jul 28, 2022 | 07:44 AM
  #52
strych9's Avatar
strych9
Originally Posted by wombat457
Because there is a thing called a "Statute of Limitations" on manufacturing faults that the manufacturer is aware of and does nothing about, such as in this case. It is ensuring that if or when HD does nothing and something happens to the OP or any other person as a result of HD negligence - it can be litigated as it should be.
Why do so many people automatically jump to defend unconscionable corporations?
False. Patently.
Old Jul 28, 2022 | 10:49 AM
  #53
AJSHOVEL's Avatar
AJSHOVEL
Originally Posted by 686 Shooter
Um, maybe they replaced the info screen without replicating the problem because as you said, it was a known issue? I don't believe this is a known issue with Harley's. You should start a dealership and throw parts at problems when the actual cause of the problem hasn't been diagnosed. That's a great way to go broke.
Should I though? Wasn't there a code on his bike?
Maybe I just have the wrong idea on what we used to call "Customer Service"?
Maybe you're ok with something going wrong on your $30,000 bike? I wouldn't be.
Old Jul 29, 2022 | 09:15 AM
  #54
tmac00333's Avatar
tmac00333
I've had that happen, when you have to ride the bike for an hour or so before the problem makes itself known. Dealer tech guys won't ride if for that long. I ended up selling the bike, so I don't have a solution for you other than to threaten them with legal action and/or a physical beating.
Old Aug 7, 2022 | 02:23 PM
  #55
wombat457's Avatar
wombat457
Don't think I would take the "physical beating" option
@strych9
I'll trust my attorney's and not some name on a monitor thank you. Oh and I went through a very similar thing with Mercedes so no it is NOT false what so ever.
Old Aug 7, 2022 | 02:39 PM
  #56
SJMathisen's Avatar
SJMathisen
Originally Posted by MattLS6
Picked up a ‘21 Street Bob in May. Couple hundred miles into ownership, I’m cruising down the road and the motor randomly shuts off. Check engine light came on but no codes thrown. Thinking ok, maybe an isolated incident. A couple hundred miles later, it happens again. This time it throws a code (B2210 run stop switch inputs both).
First thing I do is pop the switch cover off to see if there’s any pinched or frayed wires, all looks good. Next thing was get the bike to my local dealer since it’s under warranty. They called and said everything looks good, they deleted the code and it’s ready for me. I push back given the safety concern and being adamant that it’s a switch module malfunction since the wiring looks ok. They regroup then call me back later, same result. I push back again, now they are gonna call Harley tomorrow; however, I’m not expecting a better result.
In my eyes, this is a serious safety concern, one with potential legal ramifications if it happens again and I get rear ended and hurt. Confirming no wiring issues, deleting the code and sending me on the way is the opposite of a fix. I asked if they will replace the module if it happens to me again, their response was “only if it occurs with a tech riding it”. That’s not feasible since it’s seems to occur once every couple/few hundred miles….
I gave my wife documented details and instructed her to call a lawyer if god forbid this happens again and something happens to me. I just don’t get it, you’d think they wouldn’t want the liability.
Am I off base here? I thought this was what a warranty was for?
I am under the inherent belief people want to do the right thing....you just have to find the right person in the food chain. I would go to the owner of the dealership...if that does not work, I would go to the HD Director of Dealer Services in Milwaukee. Document these conversations....next time this happens, send the parties you contacted a video.
Old Aug 9, 2022 | 02:37 PM
  #57
IBE's Avatar
IBE
you are forgetting 1 thing here. there are NO mechanics anymore just parts changers.
Old Aug 13, 2022 | 09:31 AM
  #58
AV8B6015's Avatar
AV8B6015
6th Gear
I'm glad you got it sorted. For those defending the dealer, I get it. But in a case like this, one can't help but feel like the dealership doesn't believe the customer. Remember that the mistrust of dealerships is not unreasonable in most cases, it's earned. Not just Harley, but nearly every dealership in existence. If you really want to lose faith, deal with any camper dealership when you need something fixed on a brand new camper.
If dealers believed in good faith customer service, people would start to trust them again.
Old Aug 13, 2022 | 06:01 PM
  #59
almostakeeper's Avatar
almostakeeper
The dealer replaced the left switchpak on my 2014 when it failed to start in gear with the clutch in. A getting wet issue. Bike is 8 years old as of last month and that's the only problem I've ever had, not counting all the mods I've done over the years that would be considered somewhat cheesy.
jeffjackman
2014-2024 Touring Models
Apr 19, 2019 12:46 PM
smokingpig
Apr 25, 2016 06:50 PM
KGSloan
18
Oct 29, 2014 10:04 AM
baggerider
Apr 15, 2008 04:40 AM
Naz_Man
Aug 2, 2007 08:31 AM
