Think haydon's are great? Do yourself a favor, get the bike running with one of them installed, open the cover and put a timing light on it and get shocked at how loose and then big S wave the chain gets at 2500+ RPM's, The Haydon is just bouncing it's little cheap *** off almost allowing the chain to touch a screw boss on the top of the primary.
you already did what I would have suggested, had an issue with one of the fasteners on my primary when I changed fluid, my son and I actually looked at it together because when **** like this happens, I can start to get a bit grumpy....my son works in a machine shop so stuff like this is his jam...we tried to tap in the bit, but even though it stuck in, as soon as we started to turn it, it started stripping out, so i backed off and went with a larger bit....and i tapped it in until I couldn't pull it straight out with fingers....this ruins the fastener, but once I got the wrench on the bit, it creaked and snapped loose
You probably need to weld a nut on that with a MIG welder at this point. If somehow that didnt work, I like the idea of drilling off the head and then removing just the threaded part of the bolt (hopefully with the same MIG trick, but if not, perhaps with vice grips).
Average garage skillz guy is not drilling out a snapped off easy out by hand, the broken hard material will screw you with the weld trick here too, weld will pop off the first of pressure you put on it, both these ideas will just make the issue worse.
This. Slot the head of the fastener with a cut off wheel and loosen it with a hand impact driver (the kind that you hit with a hammer).
Can't count the number of them I've had to do that when they didn't have the # 3 phillips and rounded the heads out on the old bikes.
Pro tip for anyone else who may find themselves needing to pull the tooth block, get a big punch or 1/2" rod and smack the bolt head a couple times before you try the allen. It shocks them loose so the socket isn't taking the full brunt of the force.
I have done a lot of broken and damaged bolt removal over the years. Welding is a very effective way to get them, but you have to be set up properly and be pretty good using a decent welder. What I would do on this one is get a thick washer with a inner hole a little smaller than the OD of the damaged screw. Welding the washer to the screw is easier than trying to weld a nut with a small ID to it, and you can get good weld outside of the broken extractor. Grind that weld smooth and then get a nut, maybe a 5/8 or 3/4, whatever ID is just smaller than the thick washer, and then weld the nut to the washer. Don't go after it while it is still orange hot, but remove it while it is still hot so the heat overcomes the Loctite. It will come out. Most times you can get a good bite on the outside of the thick washer with pliers or vise-grip and spin them out, but having to work inside the primary you won't get a good angle on anything so a nut and a socket wrench is what I would do.
A carbide burr on a die grinder would be my second choice. Get the broken extractor out of there before you can move on to anything else.
OP, if you are not set up well to tackle it, just take the bike to a welding or machine shop and let them do it. Probably won't charge you more than a half hour labor and it will make it easy for you and not damage anything.
That's all well and good if there isn't a snapped off easy out or twisted off allen bit in the middle of it that'll get the weld, the whole harder dissimilar metals thing gets real then. Harder & tool steel don't like Mr Mig spot welds, it'll pop right off soon as you put a little pressure on it. Ain't day goes by on the job I'm not trying trying to clean up a mess just like this from our floor mechanics buggering **** up just like it on the robot end tools, busted drill bits and extractors from monkeys who couldn't drill a straight hole with a drill press.
I wasn't aware until you just mentioned it that there was a broken piece of ez-out in the hole, but I see it now. There is no drilling that out--that needs to come out. The MIG trick may still work, but a large nut will be needed to ensure that the puddle has mostly bolt in it and not ez-out.
Taps and EZ-outs and things like that are your worst nightmare when they break. There is no drilling that with anything that'd realistically be used in any normal drill.
