Buggered bolt extraction
Hayden M6 chain tensioner install
I noticed from the jump that one of the flat head screws, holding the rear adjustment bracket, was gonna be challenging. It doesnt have well defined ridges in the screw head. If not for the other screw, I wouldnt have known for certain that its a T40. I also learned the factory used red Loctite on these.
Before any attempt at removing, I sprayed it with PB Blaster and heated it with a propane torch.
I tapped a T40 socket into place, but it wouldnt let me put enough torque on it to move the screw
I then drilled it and tried a # 3 screw extractor, better grip, but same problem cant get enough force on it to budge. I eventually snapped the bit.
Im considering sacrificing a ball end Allen socket welding it into/onto the screw. All I have is a arc welder, its a tight space and Im a shitty welder to boot.
Any other ideas are appreciated
Second is 1/8" carbide burr bits, get a couple and get busy boring the broken easy out to size, this one is a straight head in attempt like drilling so the shell & chain don't need to come out, best if does but you can wrap and cover everything to keep the grit out. The heat generated during this will kill any loctite and with a steady hand you can core that bolt completely out and not trash the threads in the primary. Helicoil can fix that if it does oversize on you,
Lastly throw that f**king Hayden as far as you can please, was a piece of **** 40 years ago they haven't magically gotten any better since.
This is usually my first step in broken bolt removal.
If you are using a torch to neutralize the LocTite, don't heat the bolt to cherry red because it will cool too quickly and become brittle.
I can always button things back up with the stock adjuster
