Patch or replace tube?
Old Oct 21, 2023 | 06:20 PM
RHD51's Avatar
RHD51
Default Patch or replace tube?
Finally had my first flat tire, at over 70 yrs. old, guess it had to happen sometime. I went to roll the bike out for a ride, on one of the few nice days left this season, and instantly realized something was wrong. A quick inspection revealed the rear tire was flat and tire gauge revealed 0 PSI air pressure. I rode a few days ago and topped off the air pressure before riding. Did not notice any low tire when I got home and parked in the garage. I consider myself a very fortunate person and once again that proved to be true. To find a flat tire at home, in the garage, is a way better scenario than any other I can imagine.
My question is; Do people still patch inner tubes? or should I just replace the tube? My first thought is to do it myself and patch the tube. I can remove and reinstall the rear tire. I would have to buy a patch kit or tube and a set of tire irons to remove the tire. I have not done that before but believe I could accomplish it.
My local dealer installed the tire and tube and balanced the wheel for $60.00 I expect they would want the same just to replace the tube. I'm beginning to think that it would be smarter to just take the wheel to the dealer or local Indy and let them do it vs. my buying the tire irons that I may never use again.
Old Oct 21, 2023 | 06:21 PM
MCRD'71's Avatar
MCRD'71
How's your luck?
Old Oct 21, 2023 | 06:30 PM
RHD51's Avatar
RHD51
Originally Posted by Garage666
How's your luck?
Considering that I just said that "I consider myself a very fortunate person", I would say good!
Old Oct 21, 2023 | 06:35 PM
Uncle Larry's Avatar
Uncle Larry
Sounds like $60.00 would be well spent
Old Oct 21, 2023 | 06:40 PM
702's Avatar
702
I patch tubes and plug tubeless tires.
Old Oct 21, 2023 | 08:04 PM
chopper_man's Avatar
chopper_man
They already have to dismount/mount/balance your tire for 60$ to either patch or replace it. 10$ for a tube. Seems like a no-brainer to me.
Old Oct 21, 2023 | 08:08 PM
CoolBreeze3646's Avatar
CoolBreeze3646
If the tread is good and there are no tears/big holes on the tire, put a new tube in it and be done with it.
If you patch it, put it together and it leaks, you will be just doing the job again.
May want to check your valve stem and or see where it is leaking first.
Old Oct 21, 2023 | 08:22 PM
RANGER73's Avatar
RANGER73
As long as it's not a 3 piece patch.
Just kidding
Patch the tire if it's still got life in it.
And replace the tube, they're inexpensive and the tire's off anyway.
Old Oct 21, 2023 | 08:27 PM
2AMGuy's Avatar
2AMGuy
Community Influencer
I'd patch a tire (not plug) but I'd never patch a tube.
Old Oct 21, 2023 | 08:53 PM
Y2K's Avatar
Y2K
This,replace it even if you do it yourself.
