Welded wheels, any experiences
Old Feb 28, 2024 | 10:12 PM
that$pit's Avatar
that$pit
Default Welded wheels, any experiences
I need to replace the back wheel on a 2012 wide glide.
I'm considering OEM from the dealership or a full front/rear swap to these ones made by Led Sled.Led sled challenger invader
It would just be nice to not worry about, or have to clean around spokes anymore... and i really like the simplicity of these. Plus their price is reasonable.
But i started second guessing the welded construction. Anyone have experience, good or bad with welded construction wheels? Or these wheels in particular? The pot holes here are terrible and the idea of a catastrophic failure scares me.
Old Feb 29, 2024 | 09:05 AM
NoRegerts's Avatar
NoRegerts
Some wheels aren't even welded, the outer rim is heated and the insert is frozen. Then they're fit together and locked together forever, without a molecular bond.
Those wheels look cool. I wouldn't be worried about the welds, but the overall design seems to be minimal to me and I'd be concerned about a pot hole bending the rim. Even OEM cast wheels can be destroyed in a bad pot hole.
Old Feb 29, 2024 | 09:40 AM
RK4ME's Avatar
RK4ME
I would inspect the welds closely once a year to look for any fatigue cracks. I would also ask about the weight of those wheels and compare that to the weight of an OEM wheel.
Old Feb 29, 2024 | 09:52 AM
pgrchaplain's Avatar
pgrchaplain
FYI, All Steel Car Wheels are Welded. Go for it!
Old Feb 29, 2024 | 10:02 AM
jake24lt's Avatar
jake24lt
DOT tested?
Old Feb 29, 2024 | 10:31 AM
Goose_NC's Avatar
Goose_NC
Originally Posted by jake24lt
DOT tested?
Does DOT actually test anything? Or do manufacturers state that they comply with DOT?
Old Feb 29, 2024 | 10:45 AM
jake24lt's Avatar
jake24lt
It appears that any tire and rim that runs down a public road is required to be "certified" for road use. But it pretty much says, the DOT doesn't do testing and relies on SAE standards of compliance for certification. If you want to be bored to tears, read below.
https://www.govinfo.gov/content/pkg/...sec571-120.pdf
Old Mar 1, 2024 | 09:53 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Those look like the old Invader wheels from back in the day.
Old Mar 1, 2024 | 10:50 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Has anyone ever watched a set of wheels or anything for that matter being produced using the Friction Welding Process?
Claudio21
Apr 21, 2022 05:08 PM
MCRD'71
13
Dec 19, 2021 10:18 AM
7125
34
May 11, 2018 08:08 PM
harfooz
Jul 11, 2012 08:40 PM
drhooligan
Aug 22, 2009 08:18 PM
