cams
Old Dec 11, 2024 | 03:49 PM
rawarren01@mail.com's Avatar
rawarren01@mail.com
1st Gear
Default cams
I have a 2019 street glide. I had a thunder Max tuner on it. But through a serious of unfortunate events, it was removed.
I looked into putting cams to get the power back that I had before, but I am overwhelmed. Can someone recommend how I can figure out what I want? I like quick like when the light changes. I'm from 0 to the speed limit, and I do a lot of highway cruising, if that helps for trying to decide what cam I use.
The dealerships are quite vague about trying to assist me with what i want. I guess they are afraid they may recommend something that I do not like.
Old Dec 11, 2024 | 03:58 PM
Tommy C's Avatar
Tommy C
If you liked it with the Thundermax, why not just buy another one to replace the one that you lost? This doesn't need to be complicated. The thing is, if you change the cam, you're going to need a tuner no matter what...
Old Dec 11, 2024 | 04:26 PM
2500hdon37s's Avatar
2500hdon37s
Take a look at the Fuel Moto dyno sheets. Sounds like you want a "torque" cam so something that makes more torque than HP and does so lower in the RPM range. So you'll want to look for a cam that has a strong torque curve at lower RPM's.
https://university.fuelmotousa.com/dyno-charts/
Old Dec 11, 2024 | 04:58 PM
YZR's Avatar
YZR
Yeah, that ^
Old Dec 11, 2024 | 07:30 PM
cobra23's Avatar
cobra23
I have a 22 Street Bob and 24 Fatboy and both have a thundermax, redshift 468 cam, ported 55mm aluminum intake, and 5.5 injectors. Thundermax has a specific map for the RS468. Since you have a 2019, I would look at an upgraded oil pump and cam plate.
Performance is very strong and smooth, with lots of torque. Torque comes on low and there is plenty of power at 4K and above. Before I chose a cam, I studied all the dyno charts on Fuel Moto and called Zippers to discuss the RS468. I am very happy with my decision.
I also added a billet compensator ramp and rekluse clutch for worry free hot rodding, plus the required exhaust, air cleaner, lifters, cam bearing, and adjustable push rods.
Old Dec 11, 2024 | 08:26 PM
NorthWestern's Avatar
NorthWestern
There is only one cam in an M8.
RS468, TTS100, or 22X is what you seek. Get a PowerVision and a tune to match with your new cam AND THE RIGHT PIPES to pull it all together.
Old Dec 11, 2024 | 10:32 PM
RK4ME's Avatar
RK4ME
FuelMoto can set you up with a tuner, pre-programed. Don't open the engine if you don't have to.
markwolula
Jun 29, 2024 06:25 PM
michaelhd1340
Apr 6, 2018 12:58 AM
dzzbob
Oct 25, 2015 09:34 AM
rodney123456
Jun 26, 2012 09:07 PM
kensim
Jul 14, 2007 01:55 PM
