Setting PIN on 2002 model...
If you want to Change the PIN do the following -
with Alarm OFF flip the Run/Stop Switch to Stop
Cycle the ignition switch 3x - on, off, on, off, on AND LEAVE IT IN THE ON POSTION
Press the left turn signal 2 times and release
Your turn signals should flash
Press the key fob 2 times
The dealer code should now be displayed on the Odometer...if nothing is displayed the dealer has not entered a code.
Press the left turn signal 1 time and the LED key light on the speedo will flash.
The first number should be blinking. Use the left turn signal to change the number
to move to the next number press the key fob 2x then use the left turn signal to change the next number
When you have changed your PIN turn the igntion off.
To enter the PIN number (if you have lost the key fob)
Turn your Run/Stop switch to STOP
Turn your Key to the Accessory position
Hold BOTH left and right turn signal buttons until the key LED on the speedo blinks
Pressing the left turn signal button until the first number of your PIN is displayed
Press the right turn signal to enter that number and move the the next number postion
Use the left turn signal to enter the next number and the right turn signal to accept
once all 5 digits have been entered press the right turn signal once to finish.
Again, this is from the video I just watched and not from personal experience and it's for the '06 and might not apply to the '07
Sorry it took so long to get back to you. This info is directly out of my 2002 ownerâs manual.
How to Program a Personal Entry Code (codes are five digits)
1 Set RUN/OFF switch to OFF. Verify that security lamp is NOT blinking (vehicle disarmed)
2 Turn IGN key ON-OFF-ON-OFF-ON
3 Press LEFT turn switch 2 times and release. (2 flashes for North America)
4 Quickly press key fob button 2 times and release
5 Press LEFT turn switch 1 time and release
6 If code previously entered, count flashes for number and then press and release left turn switch to advance through the digits.
7 Quickly press key fob button 2 times and release
8 Press LEFT turn switch 1 time and release
9 If code previously entered, count flashes for number and then press and release LEFT turn switch to advance through the digits
10 Quickly press key fob button 2 times and release
11 Press LEFT turn switch 1 time and release
12If code previously entered, count flashes for number and then press and release LEFT turn switch to advance through the digits
13 Quickly press key fob button 2 times and release
14 Press LEFT turn switch 1 time and release
15If code previously entered, count flashes for number and then press and release LEFT turn switch to advance through the digits
16 Quickly press key fob button 2 times and release
17 Press LEFT turn switch one time and release
18If code previously entered, count flashes for number and then press and release LEFT turn switch to advance through the digits
19 Quickly press key fob button 2 times and release
20 Turn IGN key OFF
21 Write down code in ownerâs manual
22 Arm the Security System and attempt to disarm using personal code entry
Entering a Personal Code to Disarm Security System
1 Turn IGN key to ACC
2 Hold BOTH turn switches in until confirmation (security lamp blinks at fast rate)
3 Enter first digit of code âAâ by pressing LEFT turn switch âAâ number of times
4 Press RIGHT turn switch 1 time
5 Enter second digit of code âBâ by pressing LEFT turn switch âBâ number of times
6 Press RIGHT turn switch 1 time
7 Enter third digit of code âCâ by pressing LEFT turn switch âCâ number of times
8 Press RIGHT turn switch 1 time
9 Enter fourth digit of code âDâ by pressing LEFT turn switch âDâ number of times
10 Press RIGHT turn switch 1 time
11 Enter fifth digit of code âEâ by pressing LEFT turn switch âEâ number of times
12 Press RIGHT turn switch 1 time (security lamp stops blinking â system is disarmed)
