main fuse keeps poping
Old Sep 13, 2007 | 07:28 PM
big rob's Avatar
big rob
Stage III
Default main fuse keeps poping
i have a 2005 roadking and my main fuse that goes from ingtion to starterkeeps poping ,i already checked all my conections,ground wires ,can it be the starter ,if any one can help i really appreciate
Old Sep 13, 2007 | 07:34 PM
Kolni's Avatar
Kolni
Default RE: main fuse keeps poping
Maybe something is drawing to much current?
Old Sep 13, 2007 | 07:36 PM
Ganooch's Avatar
Ganooch
Sounds like you have a wire making contact and shorting out. Have you recently spliced anything or reattached a part and crimped a wire?
Old Sep 13, 2007 | 07:42 PM
John TN's Avatar
John TN
ORIGINAL: big rob
Low is correct,,, it's a hot wire that's grounding out 12 volt +,,, either from handlebar switch to the starter motor or around the starter itself. If you have a volt meter you can test the wires for continuity to ground and find it that way if it's not an obvious indication such as a burnt, rubbed throughor pinched wire. Good luck with it,,, electrical is some of the hardest to diagnose. As Low said any work been done on the bike lately?
Old Sep 13, 2007 | 08:49 PM
big rob's Avatar
big rob
Stage III
i havent had any work done on it , sometimes when i change the fuse im able to ride for a week or two untill it happens again, so u guys dont think its the starter
Old Sep 13, 2007 | 08:53 PM
YUCK's Avatar
YUCK
Does it happen when your riding,,,or starting up???
Old Sep 13, 2007 | 08:55 PM
volkdeluxe's Avatar
volkdeluxe
There has to be a short somewhere...
Old Sep 13, 2007 | 09:17 PM
tlb's Avatar
tlb
I would not think it is the starter. ask yourself a few questions. what, when, where and you will find the why. If it happens when you are starting the bike ie thumb on the start switch then it is something in that circuit. as said before test it with a multimeter for a short to ground. if it isnot in that onethe try each circuit one at a time and try to isolate it. if it happens going down the road try and remember exactly what you were doing at the time it popped.
good luck in finding it. one lat thing is does it happen after you wash the bike? if so you may have water shorting it out.
Old Sep 13, 2007 | 10:02 PM
Wolhar's Avatar
Wolhar
[:@]Electrical Problems, they are like chasin' a ghost!!!
Old Sep 14, 2007 | 09:31 AM
big rob's Avatar
big rob
Stage III
it happens about 10 min after im on the road
Outdoor_fun
Electrical/Lighting/Alarm
Jun 5, 2019 09:19 PM
JMSportster1
Feb 6, 2019 05:31 AM
AlgorNick
EVO
Jun 19, 2011 08:00 PM
dFREDb
May 20, 2010 11:07 PM
tmr931
Ironhead
Sep 12, 2007 10:15 AM
