Factory Set Up
Old Sep 22, 2007 | 10:39 AM
Redmondp's Avatar
Redmondp
Default Factory Set Up
How does everyone feel about it. Air shock psi. Tire pressure. Today I took my first good ride (350miles)since I got it Labor Day. At 70 mph. the front wheel vibed/wobbled and the rear was a little sluggish. I guess my question is what are your tire pressures F/R and if you have the air shocks, how many pounds are you putting in them. Or, is what I am feeling normal.
Old Sep 22, 2007 | 10:43 AM
electaRICK's Avatar
electaRICK
Default RE: Factory Set Up
why not do a pre ride check,,,, owners manual will tell you what is the rcomendations.
should do it least once a month
Old Sep 22, 2007 | 10:56 AM
dswansbiker's Avatar
dswansbiker
Front wheel vibrating and wobbling is not normal. Front wheel could be out of balance. I would pull it off and have it double checked.
Old Sep 22, 2007 | 10:57 AM
Redmondp's Avatar
Redmondp
Ok, I guess that's a answer. I was just wondering how other 07 Road King Classic riders felt about it. Is the bible always the answer. Number Please.
Old Sep 22, 2007 | 01:14 PM
drdiesel1's Avatar
drdiesel1
Minimum air pressure for tires should be 36 PSI I run 15 PSI in my rear shocks on both the SG and EGCU.
Old Sep 23, 2007 | 12:42 AM
Redmondp's Avatar
Redmondp
ORIGINAL: drdiesel1
Thank you. I will have to check and correct to see if this helpsout.
Old Sep 23, 2007 | 02:24 AM
txfxstrider's Avatar
txfxstrider
What are you running in them now?
Old Sep 23, 2007 | 02:32 AM
Redmondp's Avatar
Redmondp
Front is 31 psi. and Rear is 36. Air shock is at 10 psi. All factory/dealer set. That's why I was asking the question. I think maybe a change to the psi's may help. We will see.
Rimfire03581
Jan 8, 2017 03:28 PM
CLL375
Jun 4, 2012 01:25 PM
jefnightrain
Mar 27, 2010 09:12 PM
Brooklyn Devil Dog
Jan 26, 2010 10:09 AM
anubisss
Sep 25, 2007 11:17 PM
