Whitewall cleaning tip
Old Nov 2, 2007 | 11:27 AM
jmehal's Avatar
jmehal
Default Whitewall cleaning tip
Wasdoing aquick detail onmy Ultrathe othernite in anticipation of riding to work the next day. Iwent to clean the polished outer rim area on the front wheel, so I got out my trusty Honda Spray Polish, sprayed some on that area and wiped it down and they looked pretty decent.
Some of the spray had gotten on the whitewall stripe so I just wiped it real quick with my rag and noticed that spot came pretty clean. Not sparkling bright white like when done with SOS pad mindyou, but pretty darn clean. So I hit the rest of the whitewall on both sides and wiped itoff in one direction with my finger covered in a rag.That's all it took, no back and forth or scrubbing, just wiped in one direction all the way around.
thought I'dpass that along.
Old Nov 2, 2007 | 11:33 AM
petemac's Avatar
petemac
Default RE: Whitewall cleaning tip
I use the Mr. Clean Magic Erasers and they work great and take two minutes.
Old Nov 2, 2007 | 11:41 AM
I am Jerry's Avatar
I am Jerry
Magic Erasers kick some serious *** when washin' the bike.
The Honda spray mightbe good for a dry clean up. I'll try it sometime.
Old Nov 2, 2007 | 11:50 AM
TwiggyAZ's Avatar
TwiggyAZ
SOS??? Ahhhh! Isn't that a little abrasive on the beautiful whitewalls?
I use Mr. Clean also and finish off with a spray.
Old Nov 2, 2007 | 01:53 PM
Amodump001's Avatar
Amodump001
Put a little gas on the rag,
Old Nov 3, 2007 | 08:34 AM
wehohl's Avatar
wehohl
The white wall is quite thick. Dunlop Tire says SOS is acceptable cleaning method.
Old Nov 3, 2007 | 08:43 AM
Cliff Diver's Avatar
Cliff Diver
simple way is comet and a good brush most of the time you can find them both already around the house been usin that for years on cars and works like a charm
Old Nov 3, 2007 | 09:19 AM
electaRICK's Avatar
electaRICK
zip tie 2 toothbrushes on the inside of your forks,,,,,, cleans while you ride!
Old Nov 3, 2007 | 10:47 AM
dog155's Avatar
dog155
Bleachwhite and a scouring pad works great for me.
Old Nov 3, 2007 | 08:44 PM
jmehal's Avatar
jmehal
PS
The"tip" was a way to clean them between washes.
