Chrome or Stainless Bolt Kits
Old Feb 16, 2008 | 06:54 AM
HEYENG's Avatar
HEYENG
Default Chrome or Stainless Bolt Kits
Getting ready to tear down and do the 95 kit and cams thinking of a bolt kit anyone use either, imthinking stainless steel, but any advice after using either
Old Feb 16, 2008 | 07:32 AM
model1911a's Avatar
model1911a
Default RE: Chrome or Stainless Bolt Kits
I'm a tight a$$. I polished stainless steel. Every day at work over my lunch time I would chuck up a bolt in the lathe and polish the head. Would do 3 or 4 each day. Stainless won't rust like chrome. So I say stainless..........
Old Feb 16, 2008 | 07:42 AM
Da Gumpmeister's Avatar
Da Gumpmeister
ORIGINAL: model1911a
Finally found someone on here as cheap as I am. I am LMAO at your post. I do the exact same thing, 1911. "cept I do my polishing in the gurdge. And my son works at a major home remodeling center (Name with held to protect the innocent ) that stocks stainless bolts. When I build a "show" bike, I use chrome for the visible, and polished stain for the rest. On the "road warrior" I use stain for almost the whole build. I use "anti-seize" compound on the threads to prevent galling, or loctite if it is a critical component. I posted a list of stainless polishing products in an earlier thread if anyone is interested.
I'm GUMBY Dammit !
Almost forgot, 1911 hit it on the head. The real benny with stainless, 'pecially if you use allen head caps, you DO NOT get that little bit of rust in the allen that is fugly and impossible to get out or polish.
Old Feb 16, 2008 | 07:57 AM
electaRICK's Avatar
electaRICK
"I use "anti-seize" compound on the threads to prevent galling, or loctite if it is a critical component."
Da Gump,,, made a very good point,,, as when I worked at the Nuke plant,,, if we used stainless bolts, if they galled, or cross threaded,, whatever,,,, you have a nightmare!!! not a easy fix!!
so, ya just gotta be carefull!!! And use thread lube.
Old Feb 16, 2008 | 08:03 AM
Geoff's Avatar
Geoff
Stainless.
Old Feb 16, 2008 | 09:12 AM
model1911a's Avatar
model1911a
ORIGINAL: Da Gumpmeister
I'm GUMBY Dammit !
I enjoy seeing that bike yagot. ..........Your right when you said to antiseize them. I forgot to mention that part. Thanks for adding that in!
Old Feb 16, 2008 | 09:15 AM
Road King Kong's Avatar
Road King Kong
stainless
Old Feb 16, 2008 | 09:16 AM
JGroves's Avatar
JGroves
ORIGINAL: Geoff
Stainless.
+1 I live near trhe ocean. Chrome allen head bolts wil rust here on the inside no matter what you so.
Old Feb 16, 2008 | 09:30 AM
BigGeorge's Avatar
BigGeorge
I used stainless from Diamond Engineering. You can buy 1 bolt or entire kits. You can see their stuff at www.depass.com/Not cheap, but quality stuff....................BG
craigcrewcheif's Avatar
craigcrewcheif
Polish the stainless. When rebuilding I try not to use torx just Allen cap head whenever possible.
