Fork Lowers Leak Please Help!!
Old Mar 19, 2008 | 10:55 PM
pwer pla's Avatar
pwer pla
Default Fork Lowers Leak Please Help!!
Installed new lowers, progressive springs seals etc. etc. Got everything back together and all seemed well. Took the bike over to a buddys so he could do some paint touch up for me (heated garage)and low and behold I start to get a leak around the seat pipe screw (screw in the bottom of the lower fork tube that screws up into the seat pipe). This screw was a bitch to tighten when I put everything back together, I pulled down on the lowers to put some tension on the seat pipe (per service manual)and tightened as well as I could but could still feel the seat pipe rotate inside the fork a when I go it so tight, the tourque value is not that high for the screw so i figured I was ok, no such luck. My buddy who has done extensive work on his bike and in a mechanic by trade suggested taking the forks apart and cleaning the seat pipe screw and threads and reinstalling them with some gray silicone so this is what I am planning. Any other tricks or tips to fix this would be appreciated. The wife is going through withdrawal from not riding and I am about to go nuts having a bike that is less than perfect. Please help. Thanks
Old Mar 21, 2008 | 09:44 AM
sqdealgeorge's Avatar
sqdealgeorge
Default RE: Fork Lowers Leak Please Help!!
I usually clean the bolt threads plus the internal dampening pieces before re assembly I use clear silicone and let it dry before adding fork fluid
Old Mar 21, 2008 | 12:17 PM
lecomte38's Avatar
lecomte38
Blueballs would suggest seal them with JB WELD!!!
Old Mar 21, 2008 | 12:51 PM
Da Gumpmeister's Avatar
Da Gumpmeister
Personally, I shy away from silicone on my bikes. For something like this(because I just experienced this on the 78 FLH when I put in new seals this winter), I'd use Permtex HIGH TACK #765-1221. Non-hardening, and when you go to take things apart, it will clean up with lacquer thinner very easily. JMHO
Old Mar 21, 2008 | 01:59 PM
Landfill_Tim's Avatar
Landfill_Tim
Make sure you didn't forget the Copper gasket. Sometimes they will stick in the old legs.
I like the high tack idea. I've done6 sets of lowers and none leak yet.
Old Mar 21, 2008 | 02:02 PM
stro1965's Avatar
stro1965
Did you use new copper crush washers?
Old Mar 21, 2008 | 02:11 PM
DeJavu's Avatar
DeJavu
Is it possible you have just crossthreaded the screw?
just plain john
Jan 8, 2018 07:49 AM
skiddd
Nov 29, 2014 04:06 PM
bikersurgeon
Apr 28, 2011 08:59 AM
lhcstreetbob
Sep 10, 2009 07:36 PM
pwer pla
Mar 21, 2008 11:52 PM
