Problematic Fuel Injections pre-2002?
Old Mar 26, 2008 | 05:38 PM
kevdog's Avatar
kevdog
Default Problematic Fuel Injections pre-2002?
Someone just told me that the Fuel Injection systems in pre-2002 bikes were problematic and should be avoided. I guess in 2002 they changed manufacturers or systems. Anyone know anything about this?
Old Mar 26, 2008 | 06:35 PM
Bill03E's Avatar
Bill03E
Default RE: Problematic Fuel Injections pre-2002?
In 02 they went to the delco system,the old system it ok,but they seem to always have a problem.
Old Mar 26, 2008 | 06:59 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The older Magnetti-Marelli was a dual port setup that basically operated on engine rpm and throttle position, Then the MOCO went to the Delphi injectors, these injectors received multiple inputs to match the fuel flow to the engines needs.
Old Mar 26, 2008 | 09:47 PM
jammerx's Avatar
jammerx
I havent had any problem with mine, but any changes your are pretty much stuck with a power commander or with a Zippers or S&S solution. I havent made anychanges.
Old Mar 26, 2008 | 09:53 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
True, in 2002 they went with the Delphi ECM. Better setup and easier to tune.
Old Mar 26, 2008 | 10:22 PM
Paniolo's Avatar
Paniolo
ORIGINAL: jammerx
That's pretty much it. Keep it stock, and you should be okay. Build it up like me, and you'll need to make some changes. There is an SERT made for the Magnetti-Marelli, and it works pretty good. However the best thing I did, and the most expensive by the way, was change over to the Zippers Thunder-Max with closed loop autotune.Once you do that, you are running a Zippers Delphi version.
Old Mar 26, 2008 | 10:28 PM
kevdog's Avatar
kevdog
My bike is a 99 RK Classic with a big bore kit and PCIII,bought the bike this way. It was running like crap, wouldn't idle well or start well. Brought it to the shop and after researching the issue he said he had to replace one of the sensors and replaced another one as a precaution. It was then that he told me to avoid pre 2002 models since the FI was more problematic.
Old Mar 26, 2008 | 11:05 PM
im's Avatar
im
no issues 1998 to report
GWinkleman
Jan 3, 2012 06:29 PM
kennyjohn
Jun 15, 2010 05:14 PM
bigmack
Jun 23, 2007 12:33 AM
FreedmRider
Product Reviews
Jan 22, 2006 08:57 PM
HDF Tech
Jun 29, 2005 11:17 AM
