Keep getting gas on the tank, seems a little spurts out of the pump RIGHT before the nozzle gets in the tank.
Now when I pick up the nozzle I point it at the ground and lower it below the tank level first, let the gas splash all over the station and not my bike.
I think that's what is known as "sloppy seconds". [:-]
Use your gas cap. But then we need to bring back the thread on "where do you put your gas cap while fueling".
What I do is tilt the nozzle up till it is over the hole. Then rotate it down into the hole. I have never spilled a drop on the tank. When finished fueling I rotate the nozzle up and out.
