96B Engine
Old May 13, 2008 | 11:06 PM
Just Dave's Avatar
Just Dave
Default 96B Engine
Has anyone ever took the counterweights off of the crank on a B engine, If so, would it make the bike unrideable with it being solid mounted, or would it smooth out after you got it going? Ride Safe.
Old May 13, 2008 | 11:10 PM
cbigbie191's Avatar
cbigbie191
Default RE: 96B Engine
Uhhh, that would not be good.
Old May 14, 2008 | 12:07 AM
Just Dave's Avatar
Just Dave
Have you got any direct knowledge that it would not be good, or are you just guessing? I am just wondering if it has been done.
Old May 14, 2008 | 12:54 AM
ebeattie's Avatar
ebeattie
Try it and let us know.
Old May 14, 2008 | 03:51 AM
pistache's Avatar
pistache
[sm=badidea.gif]Why the hell would you wanna do that??[sm=badidea.gif]
Old May 14, 2008 | 06:57 AM
Just Dave's Avatar
Just Dave
I don't want to do it. Was just wondering if it would be just like the old ones, or if it would be to rough,there used to be hard mounted v-twins that were just fine... OH, nevermind, doesn't seem like anyone knows any thing about it anyway.Ride Safe.
Old May 14, 2008 | 07:09 AM
rydermike's Avatar
rydermike
I wouldn't do it for the street , however if it's for racing , GO 4 IT!! Will spin up faster , BUT less bottom end power , so if it's for high rpm WOT (Wide Open Throttle)most of the time .I did it in my racecar , but then if I was to ever put the motor in a street car I'd relpace the crank & clutch woth more liveable and driveable stuff.
Old May 14, 2008 | 10:30 AM
Harley_Dude's Avatar
Harley_Dude
Just take out the B and put in an A.
Old May 14, 2008 | 12:13 PM
ken thompson's Avatar
ken thompson
The Schlong Man
Has anyone ever ridden naked through the mountains in April? Would this be morally acceptable or a sin?
Old May 14, 2008 | 12:47 PM
Herr Monk's Avatar
Herr Monk
No, you would not want to do that. The Softail frame would get bent and mangled on the stress of all that vibration.
Have seen how much a Dyna engine moves? Now picture the entire bike being yanked around like that.
When the TCs first came out, the softails were still Evos 'till they came out with the counterbalancers.
It would not smooth out at speed, it would get worse.
Even sticking in a ruber mount, the under-body softail suspension can't take it, and you will either loose, or bend your swing-arm/suspension.
