Sticky Throttle
Old Jun 21, 2008 | 07:30 PM
softail06's Avatar
softail06
Default Sticky Throttle
I have noticed lately that when riding at a certain speed and&nbsp\\; I want to slowly increase or decrease the throtle sticks slightly. Any coments
Old Jun 21, 2008 | 08:07 PM
stro1965's Avatar
stro1965
Default RE: Sticky Throttle
Lube the cables if it's been a while.&nbsp\\; If you've had the housing off recently you might have it pushed onto the handlebar too far causing binding.
&nbsp\\;
Old Jun 21, 2008 | 08:52 PM
fonemann's Avatar
fonemann
I bet thats fun at times!
Old Jun 21, 2008 | 09:01 PM
Dorkman's Avatar
Dorkman
Lube the cables, check for binding at both ends of the throttle cables, check the butterfly nut under the throttle grip that adjusts drag.
Old Jun 21, 2008 | 10:26 PM
RMBLON's Avatar
RMBLON
It might sound so simple its overlooked, but check to make sure your thumbscrew for the throttle lock is not tight enough to put a drag on it.
Old Jun 22, 2008 | 09:44 AM
tlb's Avatar
tlb
+1
&nbsp\\;
ORIGINAL: Dorkman
Old Jun 22, 2008 | 12:03 PM
carlo's Avatar
carlo
ORIGINAL: stro1965
Lube the cables if it's been a while.&nbsp\\;\\\\\\; If you've had the housing off recently you might have it pushed onto the handlebar too far causing binding.
&nbsp\\;\\\\\\;
+1 happened to me on my 06 1200c&nbsp\\;Housing on handle bar to far. Easy fix loosen screws and back off a bit from handle bar.&nbsp\\;
Russian
May 30, 2014 10:28 PM
OldTyme
Sep 12, 2012 09:29 PM
bigrob219
Jun 21, 2012 06:06 AM
klf33
Sep 24, 2009 04:41 PM
cmhull
Jul 18, 2008 09:12 PM
