Loose Throttle Cables !!
Old Sep 23, 2009 | 01:22 AM
klf33's Avatar
klf33
Default Loose Throttle Cables !!
Hi Guys,
Since I rotated my bars forward a notch, I did loosen the housing of the throttle cables and signals to rotate it a bit.
Today though I noticed my throttle cables shaking in the wind as I ride, and as I touch them they seem a bit loose, no idea how this happened.
The small metal tubes that goes inside the bottome of the housing is coming loose, nothing will fall for sure but it does not make me feel secured.
I looked at the service book and there is no description of how to fix that .. any ideas ?
Regards
Old Sep 24, 2009 | 07:45 AM
Dagsadoo's Avatar
Dagsadoo
Mine are loose and it's a brand spanker 09 Heritage 300km on the clock. I was a bit worried, but so far everything is OK. When I go to the dealer next, I'm going to ask about it and see what he says.
Old Sep 24, 2009 | 07:51 AM
Wallaby's Avatar
Wallaby
Take the slack out of your throttle and idle cables by screwing OUT the adjusting nut on the ends of your cables at the handlebar control end (underneath the rubber sheath). Don't over-tighten, a tiny bit of play is OK.
Old Sep 24, 2009 | 09:23 AM
oldgeezer's Avatar
oldgeezer
The cables are held in the switch housing by a snap ring so they will move with the handlebars. They are fine.
Old Sep 24, 2009 | 09:28 AM
Road Head's Avatar
Road Head
There is a "method" for adjusting these in the HD service manual. I can't remember all the steps, but periodically I have to adjust mine. I wouldn't just go turning screws without referring to that first.
Old Sep 24, 2009 | 09:38 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Zip ties work well to secure them a bit, but make sure that they still avhe enough slack to work without binding while turning the bars to full ock in either direction. Mine are zip tied to my brake line down low.
Old Sep 24, 2009 | 09:54 AM
oldgeezer's Avatar
oldgeezer
Don't go dicking with the throttle adjustment screws unless you have a service manual and can do it correctly. You can adjust the throttle cable to the point where you don't have full travel and won't get full throttle.
Old Sep 24, 2009 | 04:41 PM
SpicOfTheDevil's Avatar
SpicOfTheDevil
i did it when i changed my grips...so you can do it...just make sure that at full throttle the valve in the air intake fully opens and once you let go it should snap back...
here's a tutorial:
http://www.ehow.com/video_2330186_ad...le-cables.html
TwoBlue02
Dec 29, 2012 05:00 PM
OldTyme
Sep 12, 2012 09:29 PM
Samber79
Mar 14, 2009 12:28 PM
cmhull
Jul 18, 2008 09:12 PM
nickdv9
Apr 25, 2007 08:29 PM
