Oops, its cheaper to drive my pickup truck
First off, change your own oil, that will save you $150.00 then use regular gas or mid grade if you experience any pinging. That will save you a few pennies per tank full, plus you will get better mpg with the lower octane. Also you should be getting around 8 to 10,000 miles on your rear tire. Your numbers are way off.
I read an article by Joe Minton, in "American Rider" magazine concerning octane.
According to Minton, the motor will work harder with the lower octane to achieve the same performance as High test. \\;\\\\\\; (Using more throttle to achieve the same performance) \\;\\\\\\; Minton asserts that based on that criteria, there is no monetary gain in going to regular grade gas, nor does regular improve performance.
If that were true, everyone would be using premium in all their vehicles. \\; Just ain't so.
Truck cost $27,500
Depreciation $10,000
mpg 18-20 gas $4.10 15000 miles per year
Ins. $660 per year
Service 20$ oil change every 4,000 miles
Tires $900 every 60,000 miles
1 battery $100
Registration $65 per year
Harley cost $17,500
Depreciation $5,000
mpg 42 $4.10 7,500 miles per year
Ins. $185 per year
Indy service costs $500 per year (including some accessory add on time, and the fact that services that end in 0 are more)
pair of tires $400 every 10,000 miles
1 battery $150
Registration $20 per year
My math is probably wrong but I came up with around $.75 per mile on the truck and around $.82 per mile with the Harley. I think they figure if you are going down the road at around $.80 cents a mile with anything you are doing pretty well. I would have guessed that the Harley was indeed cheaper to run down the road. My truck is a 04' toyota tundra, bike is a 06' street glide.
I don't even think it's worth my time to use the numbers...wouldn't matter anyway....13 mpg and $4.85/gallon for diesel versus 40 mpg and buying gas for a bike is a no-brainer........oil and filter change on bike is $25.00, truck takes 10 gallons of oil alone without fuel and oil filter.........
Just bought a tire and tube (got a little over 10,000 out of the last one) for around $170.00, so that makes it +/- $185 for a new rear with mount and balance. \\; It does pi$$ me off that the bike registration is almost the same price as the Duramax 2500 HD.....that's a ripoff.......
drive your truck the way you drive your bike .then let us know what it cost.
Exactly.
What I am reading here is "I drive like I'm on a race track, and cant' do my own servicing"
Exactly.
God damn you grumpy geezers have had long enough to figure it out but your too damn stubborn to realize no matter how slow you drive the damn things still gonna wear out eventually. \\; Drive fast, take chances! \\; Good ****ing grief, I'm gonna hafta chug a six pack and go for a 100mph ride naked tonight, and when I get back I'll buy that damned ASSEMBLY LINE manual and tear my frikken bike down to the frame and rebuild it. \\; ****, I'll grind off the welds and re-weld it all too, to make sure its all done right. \\; You know, all them damned poor azzed sloppy ignorant assembly line workers cannot be trusted to have worked on my bike, I'm better than that!
And I _DO_ drive my truck like I'm on a race track all the time, I heel-toe around 50mph corners and beat the crap outta it. \\; I'll trade it on a new one when it wears the hell out, and keep havin fun.
i'm going.
Many years ago I did save a lot on Jap 250/400 twins when you could buy one for +/- $1k. Rode year round in OH unless there was ice on the ground. We only had one car, an economy car at that. 300lb bikes and centerstands made maintenance easy.
I bet in a yeer or two there'll be some used bargains at dealers (probably not Harley) once cagers find out it takes a certain commitment to ride enough to pay for a bike and it's maintenance.
Buttman, please post the issue and year of your information. \\; Meanwhile, I will post the link to what Joe Minton actually said about detonation, and if you read it, you will note he says to up the octane. \\; Sheesh ! \\; Talk about destroying a top tech writer's integrity....
http://www.americanrider.com/output.cfm?id=1021915
