Engine keeps reviving
Old Jul 24, 2008 | 02:08 PM
ebeattie's Avatar
ebeattie
Default RE: Engine keeps reviving
Had the idle screw on my 07 back out and stick my throttle plate open. REALLY OPEN. Apparently the locktite had come undone and let the screw back out and hold it open. Take it in and have em check it. its located on the throttle body.
Old Jul 24, 2008 | 06:30 PM
John TN's Avatar
John TN
ORIGINAL: ebeattie
That could do it too,, if it's moved they'll have to re-calibrate the TPS as well. The butterfly on a EFI throttle body isn't electronically designed to set the idle, the IAC controls/sets the idle.
Old Jul 24, 2008 | 07:19 PM
ebeattie's Avatar
ebeattie
Erm sorry, forgot to say the "screw" was the throttle stop. TPS was ok, but when it hit a certain engine speed it set a C.E.L. ECU saw the IAC close all the way and no change in idle speed.
Old Jul 24, 2008 | 07:56 PM
JBaker421's Avatar
JBaker421
Big Kahuna HDF Member
You guys are way over my head. I don't understand my EFI Deuce in that area.
Suddenly I think I just go ride my carbed EVO Wide Glide. I can fix that...[:@]
Old Jul 24, 2008 | 08:22 PM
Whiffleboy's Avatar
Whiffleboy
I've had similar problems in the past.&nbsp\\; The past 4 months it hasn't come around again.&nbsp\\; Coincidentally, this is around the same time I stopped filling with Supreme Unleaded.&nbsp\\; Just a thought...
Whiff
Old Jul 25, 2008 | 07:05 AM
DWG05's Avatar
DWG05
Had a simialr problem with mine. Dealer replaced the ECM but that didn't fix it. They finally "discovered" the temp sensor was bad so they replaced it and all is well so far. With extended warr they tried to charge me but found out the federal emmision warr covered it.
Old Jul 25, 2008 | 07:30 AM
johnnyshrooms's Avatar
johnnyshrooms
map sensor is @ idle surge
04ctd
Apr 7, 2011 02:30 PM
questor
Jul 8, 2008 09:45 AM
KRUSE
Jun 16, 2008 07:38 PM
WIZARD
Exhaust System Topics
Jun 9, 2008 10:55 PM
Lochness
Jun 5, 2008 12:02 PM
