Rev Limit
Old Mar 15, 2006 | 11:36 PM
rde's Avatar
rde
Default Rev Limit
Most riding occurs well below 3500-4000 RPM's. Can someone explain the relevance of increasing the rev limit on a bike? I am sure there is a very good technical reason. Seems like the only time you would need it is for rapid acceleration in lower gears.
Old Mar 16, 2006 | 12:02 AM
Thorns's Avatar
Thorns
Default RE: Rev Limit
On a stock street bike, to go from 5800 rpms stock to 6200 rpms with upgraded download serves no purpose, IMHO. I think I've hit the rev limiter one time in 22500 miles. But, it sounds macho while drinking a beer with the boys, and everyone's dick is hanging out.
Thorns
Old Mar 16, 2006 | 12:15 AM
Budds's Avatar
Budds
ORIGINAL: Thorns
..... But, it sounds macho while drinking a beer with the boys, and everyone's dick is hanging out.
Thorns
** Note to Self **
If Thorns invites you to a party....... Decline humbley !
Budds...............
Old Mar 16, 2006 | 12:29 AM
BBDeluxe's Avatar
BBDeluxe
It is the "easiest" way to claim higher horsepower ratings, if that type of thing matters. Why? Because the formula for calculated HP is tourque in lb ft X rpm divided by 5520. So if you do some things to the engine to increase rpms by even a few hundred, you can see how this makes the hp # increase a lot more than if you increase the torque number, even if a rise in torque actually makes you acclerate faster starting at lower rpms. Just math.
This seems to be prevalent in the race bike arena these days, as competing brands are racing for hp #'s too. Alot of technology is going into lighter pistons, shorter strokes with wider bores, lighter valves with stiffer valve springs, etc. This way the engine can rev higher without making more torque per stroke and end up with higher hp.
Will it make the bike pull harder? Yes, in a way. Because accleration is also a factor of how quickly the engine will increase its rpms, not just how much push per revolution. In an engine that starts its power band at 9 or 10K, then increasing redline from 14.5 K to 16K does make a difference. On the race track, you are riding those bikes at between 8.5K and redline the whole time. In the real world, it doesn't translate the same way.
You can quickly see that for an engine like the HD Vtwin that pulls nicely at 2500 rpm and revs out at 5K, a few more rpms won't make as much difference.
Hope that explanation helps.
Bones
Old Mar 16, 2006 | 12:57 AM
rde's Avatar
rde
Thanks for the details. See I knew someone on this forum would have the answer!
Old Mar 16, 2006 | 09:01 AM
Fred00's Avatar
Fred00
Increasing the rev limit on the bike will not increase hp numbers. Why? Because peak hp reached before the stock rev limit anyway. The bike will still probably accelerate better with increased rev limit because you can use for example 2nd gear longer. That is, you can use the lower gearing provided in 2nd to reach a higher speed before you have to go to 3rd.
The above is true assuming the engine torque doesn't drop so low above 6000 rpm that you would actually be better off gearing up a notch. This would happen if the engine torque in the 3rd gear would be so much higher than in 2nd that it makes up for the loss in the gearbox (due to the longer gear ratio in 3rd gear).
Old Mar 16, 2006 | 10:01 AM
HDF Tech's Avatar
HDF Tech
Lots of good info here, I feel that upping the limit doesn't help much at all because you run out of cam before you hit the limiter on a stock motor so all you are doing is spinning it over. The "B" engine will live much longer without the extra RPM's also.
Old Mar 16, 2006 | 10:16 AM
Fred00's Avatar
Fred00
ORIGINAL: TCSTD
Lost of good info here, I feel that upping the limit doesn't help much at all because you run out of cam before you hit the limiter on a stock motor so all you are doing is spinning it over. The "B" engine will live much longer without the extra RPM's also.
Yeah, if the torque in the engine drops considerably before the stock rev limit I don't see any reason to raise the limit.
Does anybody have a link to a dyno chart I can look at.
Old Mar 16, 2006 | 11:52 AM
lil_gmac2's Avatar
lil_gmac2
Good write up.
ORIGINAL: BBDeluxe
Bones
Old Mar 16, 2006 | 05:52 PM
sporty2003's Avatar
sporty2003
you try to push it to high you could damage the stock vavles.
