Questions about engine break in.
Old Aug 18, 2008 | 11:19 AM
Deluxe Rider's Avatar
Deluxe Rider
5th Gear
Default Questions about engine break in.
Hi all. New member here. I'm about to be the proud owner of a 2009 Softail Deluxe and I have a few questions. I have been told two different tales when it comes to engine break in, One was that I should ride for short distances at low RPM and then let the engine completely cool off and then do it again for the first 1000 miles. The other is that I should just watch the RPMs for the first 1000 miles but otherwise just ride it. Which is better? Also has anyone used Royal Purple break in oil when breaking in their bike? Thanks.
Gavin
Old Aug 18, 2008 | 11:28 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Follow the break in schedule in your owners manual as it is very specific. Yes, you can use RP to break your bike in but run the factory fill at least 100 miles to get all the initial break-in debris out. (you will be amazed at how much garbage is in the oil at 100 miles). If you do break in your bike with synthetic oil it will take longer than 1000 miles. Several engine builders I know recommend going 2000-2500 miles with syn oil for a proper break-in before you really beat on the engine. But do change the oil at 1000 for your warranty related service. If you do the work yourself, keep a dated log and receipts of all oil service for warranty validation proof.
As for the riding and cooling which is "heat cycling" the engine. It is a good idea if you can do that. I did mine that way for the first 300 miles and went to syn3 oil at 100 miles. But heat cycling for 1000 miles could make you insane...
FWIW I changed my oil at 100,500,1000, 2500 then every 5000/1 year. No leaks, no oil consumption, very smooth operation.
Old Aug 18, 2008 | 12:21 PM
oldfartjc's Avatar
oldfartjc
Just read your HD owners manual, they're the ones who built your bike so maybe they just might know the best way to break it in. That's what I did and it worked just fine.
Old Aug 18, 2008 | 12:35 PM
barjbar's Avatar
barjbar
I wouldn't recommend synthetic oil until the rings are sealed - for the 1st 1000 miles. I agree it's in the owners manual. Just keep the rpm's under, if I remember right, 3000 the first 100 miles and then then 4000 rpms the next 900 miles. Try to vary your speed as much as possible the 1st 1000 miles. You bought a great bike.
Old Aug 18, 2008 | 02:11 PM
Deluxe Rider
5th Gear
How many RPMs is the motor turning at 60 MPH in sixth gear? Would riding the bike 27 miles at 60MPH in the first 100 miles or so screw up the break in? I wouldn't think so but the most dumb question is the one you don't ask.
Gavin
Old Aug 18, 2008 | 02:32 PM
cccbebad's Avatar
cccbebad
Just ride around, and dont lug or red line the motor for 250 miles and you will be fine!!
Old Aug 18, 2008 | 02:48 PM
vibr8ir's Avatar
vibr8ir
ride the **** out of it, it's under warranty..
Old Aug 18, 2008 | 02:57 PM
beary's Avatar
beary
Originally Posted by barjbar
I wouldn't recommend synthetic oil until the rings are sealed - for the 1st 1000 miles. .
I agree, there is no advantage to using syn oil before 1000 miles, but there is a risk of not seating the rings. In fact, it won't hurt to go the first 2500 w/o syn oil, but at least go the 1000.
Beary
Old Aug 18, 2008 | 06:33 PM
ballpeen's Avatar
ballpeen
THIS IS REALLY GOOD ADVICE, Its how I broke in mine,, And you are so right about the crud in the first 100 mile oil change.. Tim
Old Aug 18, 2008 | 06:44 PM
deadman77's Avatar
deadman77
Follow the manual. If you go over or under a little its not gonna break.
Ride it and have fun.
MikeM
