Open Primary Install help!
http://www.denniskirk.com/jsp/produc...Id=22302&mmyId=
Got mine here, cause they are just down the road. You can pull almost everything on a Harley with one of these. Clutch hub, alternator rotor, engine sprocket.
I run BDL's on both mine, the pan and the 78 Shovel. One tin primary, and one alum. w/electric.
You putting on a 3" or Pro Stock?
Directions will be straight forward.
There are naysayers everywhere, and what I'm about to tell you, you can do or not do. I use impact on clutch and motor nuts. Off is not the prob, ON is where you have to watch your P's and Q's. DO NOT OVERDO it.
Inspect the clutch hub and ring gear GOOD prior to starting. I have received hubs, with the ring gear NOT seated all the way, and it will eat up a 1 1/2 belt in less than 70 miles if the ring gear is touching the belt. I read that in Hot Bike, one time.
Ensure your outer supports (if you have them for your unit) are properly aligned, but again, the destructions will cover that.
Save ALL the pieces from your primary, etc. Much easier to sell it on EBAY, Craigslist, or likewise. IF you're gonna sell it, take a couple of pics of the old stuff, prior to taking it off, so you can show ppl, it was on a running mowsheen. I also jot down the mileage with a magic marker on the hub or someplace visible. Again, this is if you plan on selling it. (Comes right off with lacquer thinner or carb cleaner)
Got your manual for removal? Pretty straight forward. Post back, if you run into a road block. Someone here will post back.
Also, BDL has a decent (?) tech line, you can call them, too.
Good luck.
