Electrical HELL
Old Dec 30, 2008 | 12:07 AM
ranger56528's Avatar
ranger56528
should be 12v,the 6v would of went bright and then out...
Old Dec 30, 2008 | 12:33 AM
johnnyhumble's Avatar
johnnyhumble
Thanks again for the help.
Old Dec 30, 2008 | 12:36 AM
Solitaree1's Avatar
Solitaree1
if you don't have, go get, or borrow a volt meter. Get an idea of what's what.
Unless you bought it new, someone else could have already fiddled with the wiring.
You can get a cheapie meter for 20 bucks. harbor freight or someplace similar. FInd out what wire is hot under what circumstances, it should all be DC volts.
Good luck
Old Dec 30, 2008 | 12:43 AM
johnnyhumble
Thanks,
I did buy it new, over 3 years and 40,000 miles ago. I must admit, I have screwed with the wiring in one way or another on several occassions. When I took it to the dealer to have the 95 kit put in, they added the PCIII and removed a Terry Componets Module I had installed staing I had made a "rat's nest" of the wiring. Funny thing was, everything still worked.
Hopefully it is something as simple as a relay from when I wired the ground directly back to the bike.
Old Dec 30, 2008 | 10:27 PM
johnnyhumble
Well, the two small 3/8 nuts that hold the ignition and starter wires to the main circuit breaker were loose. Once I tightened them up, it worked fine. Rode the bike today and have had several people stop me to ask about it when filling up with gas. Looks like this will be a great year. Now I just have to finish the fab work on the rear fender and struts. Thanks for all the help.
Running light on
With brake activated
Old Dec 30, 2008 | 10:52 PM
ranger56528
Like it....
Old Dec 31, 2008 | 09:36 AM
DoomBuggy's Avatar
DoomBuggy
Very cool look, glad it was simple.
Old Dec 31, 2008 | 10:55 AM
JW1200's Avatar
JW1200
Sometimes it pays to check the little things first!!
But what do I know, I ride an EVO!!
WOW that is cool!
USMAMule
Jul 9, 2018 06:07 AM
LiL Bastard
Apr 24, 2018 07:13 PM
vbboatcop
Aug 14, 2014 05:50 PM
Schaub85
Jun 30, 2011 12:20 AM
JoeBobber
Mar 18, 2010 06:57 PM
