Lean Angle
Old Jan 14, 2009 | 09:19 PM
icecaps's Avatar
icecaps
Reading More Posting Less
Default Lean Angle
All the bikes on HD's site have the lean angle as per SAEJ1168. Does anyone know how this is officially measured - loaded or unloaded? Also, whats the difference between the two angle measurements?
Such as:
Lean Angle (per SAEJ1168) - 31° / 30.5°
Old Jan 14, 2009 | 09:35 PM
paul s's Avatar
paul s
The two measurements are left and right, I'm not sure on the load.
Old Jan 14, 2009 | 10:28 PM
*NIGHT TRAIN*'s Avatar
*NIGHT TRAIN*
The lean angles on my Train are 31 and 34 degrees...the difference is that the jiffy stand on the left side will make contact with the road long before anything on the right side...
I've never thought about whether the lean angles are measured with the bike at a loaded or unloaded weight, but common sense would tell me that those measurements are useless to you unless you're actually riding the bike, and it shouldn't be leaning at those angles at all if you're NOT...but then, common sense isn't that common any more...
Old Jan 14, 2009 | 10:35 PM
OhioSkully's Avatar
OhioSkully
Most usually everything is figured based off of how it leaves the factory as for load probably figuring an average rider below 200lbs and may not even be with a rider may be done with a computer or in a test shop.
Old Jan 14, 2009 | 10:48 PM
OhioSkully's Avatar
OhioSkully
Here is a pretty interesting calculator for it i found on a site:
http://www.msgroup.org/forums/mtt/to...57&whichpage=1
Old Jan 14, 2009 | 11:07 PM
icecaps's Avatar
icecaps
Thanks for the link and making my brain hurt.
Old Jan 14, 2009 | 11:38 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
This is considered too much of an angle.....
Old Jan 15, 2009 | 12:04 AM
paul s's Avatar
paul s
How do ya wreck on a straight road?
Old Jan 15, 2009 | 12:12 AM
oldairboater's Avatar
oldairboater
For some it is easy.
Old Jan 15, 2009 | 01:15 AM
ngoti8tor's Avatar
ngoti8tor
I think it was parked on the shoulder and the jiffy stand sunk in the dirt.
