changing sliders
Old Jan 29, 2009 | 03:24 PM
jd8181's Avatar
jd8181
Default changing sliders
i just bought a set of chrome sliders (lower fork legs) and i talked with a guy that has changed acouple of sets of them and said they aren't bad to change and i'm to cheap to pay harley $150 to change them. i read the manual and it sounds pretty easy. my questions are should i use harley fork oil or some other brand?? i want to clean inside of the sliders (since they are used) before i change them and i'm just wondering what i should use?? and any other advice you guys can give me.
Old Jan 29, 2009 | 03:46 PM
jimmers1817's Avatar
jimmers1817
If you're dealer will do it for $150 wouldn't be any question what I'd do.
Mine wanted $325.
Old Jan 29, 2009 | 04:04 PM
hdbe's Avatar
hdbe
no advise on the how to....but I'd probably use the hd oil
Old Jan 29, 2009 | 04:20 PM
fastglass's Avatar
fastglass
I used the screaming eagle oil(not the racing oil)and you will have to know the exact quantity for your bike as it is different for each bike.You will also need a long 6m allen wrench to get the screws out of the bottom of the forks.It really was not a difficult job as i did mine last year.Good luck!
Old Jan 30, 2009 | 11:16 AM
condition001's Avatar
condition001
its easy to do. make sure you have significant down pressure on the fork cap when you unscrew the top. (i usually use a rag held over the top to keep the cap from flying. after that, its pretty straightforward if you have a manual. you will likely need new fork seals, its recommended anyways, as well a a tool to press the seals in (you can make your own, there's a how to on here somewhere) otherwise the seals are easy to damage. i did mine, no problem. its easier if you take each of the forks off of the bike once the tops are removed. i used bel-ray fork oil, or something close to that. the oil only changes the rate at which the forks rebound; a thinner oil rebounds faster than a thicker oil. also, when you refill the forks after reassembly, make SURE the oil is at the same, correct, level in both forks.
edited for grammar
Old Jan 30, 2009 | 11:34 AM
max56's Avatar
max56
Veteran: Coast Guard
Wharf Rat
2014-2024 Touring Models
Feb 13, 2016 05:41 PM
dforeid
Jun 21, 2012 08:42 PM
SecondChance!!
Jun 27, 2009 08:05 PM
HarleyDeluxe
May 2, 2007 10:40 PM
ultravista
Oct 3, 2006 08:23 PM
