Electrical Question?
Old Apr 14, 2009 | 09:33 PM
gascap13's Avatar
gascap13
Default Electrical Question?
Headlamp has been intermittent lately. Headlight OFF (both beams) and the Hi Beam indicator is ON. Started with dim headlamp and a faint glow in the Hi Beam indicator then would be normal. Is this the normal symptom of a blown bulb?
Old Apr 14, 2009 | 10:00 PM
NoBoldRider's Avatar
NoBoldRider
Could be the bulb or, like mine, the connector might have burned up. The high beam indicator on my bike was also on all the time. If it's the connector, you can get a replacement with pigtails and barrel connectors to replace it at the dealership.
Old Apr 15, 2009 | 12:00 PM
Danowert's Avatar
Danowert
sounds like a short or a backfeed. Pull the switch cover and the headlight and check continuity at the switch and also at the plug
Old Apr 15, 2009 | 06:30 PM
gascap13's Avatar
gascap13
Found the headlight plug melted at the ground lug. Checked the bulb low beam resistance to the ground terminal to be < 1ohm. Replaced the bulb with a Sylvania Silver Streak and the plug with a plug from local auto parts store. Suspect that the nearly shorted lo beam filament was creating the back-feed. All seems well now. Thanx for replies.
Holloway2146
Electrical/Lighting/Alarm
Aug 26, 2017 01:48 AM
jimjam31
Aug 9, 2012 03:35 PM
Strick
Aug 26, 2011 06:02 AM
Nautilus
Apr 4, 2010 04:02 PM
Whiffleboy
Oct 16, 2006 01:06 PM
