Spark Plugs - Does it matter
Old May 5, 2006 | 12:58 AM
Jeff Brokenshire's Avatar
Jeff Brokenshire
Default Spark Plugs - Does it matter
I have a 2003 95ci Stage 1 Fatboy and its due for new spark plugs. There seems to be 3 different ones in the catalogue. Do the Screaming Eagle ones give any advantage, or should I just use the standard ones?
Old May 5, 2006 | 01:05 AM
PhilM's Avatar
PhilM
Default RE: Spark Plugs - Does it matter
Unless it's a high-compression build or some sort of radical config, save your $$$ and use the standard plugs.
Old May 5, 2006 | 01:21 AM
Flying Pilgrim's Avatar
Flying Pilgrim
"In theory" it could make a difference. Each plug design could have an effect on performance, but the only way is to try it, judge performance, and read your plugs. I think for the average rider it's kinda like asking "what oil should I use?".
Old May 5, 2006 | 03:18 PM
superdog48's Avatar
superdog48
As far as I know the Split fire type plugs are not that great. Go with the standard plugs. One idea is to get a set of SE plug wires,they are a little larger that stock.
nhhdrider
Jan 17, 2014 11:30 AM
wiktor
Mar 19, 2013 06:22 PM
Steel Steed
Mar 14, 2012 11:57 PM
grunt25inf
Sep 18, 2007 02:06 PM
gigiflip
EVO
11
Sep 14, 2007 07:59 AM
