trouble getting nuetral
Old May 11, 2009 | 02:15 PM
lumpy1's Avatar
lumpy1
Default trouble getting nuetral
I seem to be having alot of trouble getting my bike (99flhr) to drop into nuetral when at a red light and such. It takes so much effort on the shifter that I end up going past it to the next gear. So I just sit there like a fool going from 1st to 2nd and back, going past nuetral every time. Damn that pisses me off! I never had this problem on any of my EVO bikes. Sometimes it will drop right in there and others its no go. I tried rolling the bike a little with the clutch in and a light foot on the shift lever but it makes no difference. WTF, good thing I dont have a temper. Any thoughts ? My clutch hand is begging for mercy.
Old May 11, 2009 | 02:30 PM
AK47's Avatar
AK47
Try to adjust the clutch. My pops had the same issue with his American Ironhorse Legend and it worked perfect after a clutch adjustment.
tgarrett1's Avatar
tgarrett1
I had the same problem, still do a little not quite as bad after I changed to synthetic oil.
Old May 11, 2009 | 02:32 PM
Chicago 03 King's Avatar
Chicago 03 King
Do you still have the stock shift linkage on the bike? I went from the stock shifter having a vague feeling to not having any troubles when I replaced the sloppy rod ends with Heim Joints. The information is in this link: https://www.hdforums.com/forum/touri...int-specs.html
Old May 11, 2009 | 02:39 PM
username17's Avatar
username17
I had the problem on my bike, but I think that was because it was new.
It just started loosening up.
Just put forwards on it, so it's much easier now.
Old May 11, 2009 | 02:43 PM
RoadKingRon1's Avatar
RoadKingRon1
Wife had the same problem with her Deluxe. Changed the tranny fluid from dealer installed Syn3 to 85W140 gear oil. She's now a happy camper.
Old May 11, 2009 | 03:03 PM
Da Gumpmeister's Avatar
Da Gumpmeister
Well, if you had a pan or shovel, I'd tell ya "To get used to it".
Try the clutch adjustment scenario, first. Then the earl change, if that doesn't alleviate the issue.
The 'newer' ones, seem to work much betta. Couple of 'SMALL' design changes, FINALLY!!!! Only took 'em since the 40's, tho. Some cos. jus' don't wanna rush into anything new, ya know.
Old May 11, 2009 | 04:11 PM
Dixie Dreg's Avatar
Dixie Dreg
I switched to Amsoil and the problem went away immediately.
Old May 11, 2009 | 04:13 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Adjust the clutch, adjust the clutch cable, and change the transmission oil to redline heavy shockproof.
Old May 11, 2009 | 04:26 PM
lumpy1's Avatar
lumpy1
I'm using amsoil in the tranny, dont think thats the problem. I ordered a replacement linkage rod with hiem joints in it from e-bay. I'll adjust the clutch as well, hopefully that will cure it. It really seems like the linkage is binding the more I look at it. Thanks for the ideas.
