BIG BORE
As far as power is concerned, I'm pretty happy with the 88 although I'm dreaming about a Woody's Blower.
I think if I had it to do over I would just do the gear drive cams.. Andrews 21g or 26g.. to get rid of the stupid chains and their tensioners (had one go bad in my '00 RK at 17k miles) and install adjustable pushrods, (to avoid pulling the heads), tweak the oil pump and carb (or F.I. system), high flow air cleaner and free flowing slip on mufflers, and that's it, most bang for the buck in my opinion, and least invasive into the motor. the money you saved on pistons and jugs will buy alot of gas....
No... you won't post monster numbers on the dyno... or outrun your buddy's VTX and maybe the other metrics, but it will get you quite a bit of "seat of the pants" power over stock.
I have read here and other places that when you're close to or over 100 tq & hp, that you should change out the roller bearings in the cases for tapered ones, there are some pics here of bearings that have gagged, that means more $, and it is quite easy to get caught up into chasing more & more power with more & more money,,,, been there, done that.... I used to do some drag racing, and it just got plain stupid what I would spend to gain 2 tenths......
"Speed costs Money, how fast do you want to go?" is so true...
Well, there's my long-winded opinion, I hope it helps,
good luck and do whatever you think will make you happy, afterall, that's what counts and what it's all about anyway!
Bottom line is I feel that I would be just as happy with 88" and aforementioned mods, without the expense of going to 95"
K.
Hey I can afford this stuff more now that I've quit smoking, my reward to myself.
I'm leaning towards the six-speed mod at this point.
Either do the 95 or add cams to your stock bore..............wake the engine up!
Final cut, I would think twice about the 6 speed without some motor work. THe final drive is pretty low for a stock motor. Though the softail 6 speeds are different than the dyna/touring 6 speeds.
Now that I have said all this keep in mind I am not a wrench and everything said here is just seat of the pants and a personal opinion.
