Oil leaks
Old Dec 9, 2009 | 09:51 AM
Metal4God's Avatar
Metal4God
Default Oil leaks
I own a 2008 Softail custom With A little over 5000 miles on it, I have had to have oil leaks fixed twice since I bought it. The leaks were in 2 different areas of the engine.
Is this just sloppy work from the factory or is this a design flaw?
Old Dec 9, 2009 | 09:52 AM
jimsflh's Avatar
jimsflh
Maybe, but more likely improperly installed seals, or similar issue. Where was it leaking from both times, and what was done to accomplish stopping the leak?
Old Dec 9, 2009 | 09:57 AM
schumacher's Avatar
schumacher
on something that new, just keep an eye on it. You buy it used, or it have a warranty still?
Old Dec 9, 2009 | 10:41 AM
Metal4God's Avatar
Metal4God
I bought it new in 2008 and is still under factory warranty. The first leak was at the top of the cylinder head on the front cylinder, the second leak was at the bottom rear cylinder, both times new gaskets were installed.
Old Dec 9, 2009 | 10:50 AM
schumacher's Avatar
schumacher
well then definatley keep them on this. Shouldn't be anything major. The stock gaskets are (or at least used to be) pretty crappy anyways.
Old Dec 9, 2009 | 12:45 PM
skully_68's Avatar
skully_68
well like they say if ya want some thing done rite best ya do it your self
Old Dec 9, 2009 | 02:05 PM
schumacher's Avatar
schumacher
unless you can get it done for free
Old Dec 9, 2009 | 02:19 PM
BadBobOk's Avatar
BadBobOk
Harley has been working to resolve this problem for over a century now. I heard from a factory rep that it should be fixed beginning with 2011 models.
Geoff's Avatar
Geoff
A 2005 Ultra Classic I used to ride had porosity in the engine cases. With only 3K miles, it leaked oil like a sieve. The motor had to be removed from the frame, split open and rebuilt with new cases engraved with the bike's VIN. A MoCo rep from Milwaukee visited the dealer to authorize the repair, which was performed under warranty.
Old Dec 9, 2009 | 02:56 PM
Big Gator's Avatar
Big Gator
I was asked, "What do you call a Harley that doesn't leak"? Not knowing the answer I was told, "Empty"
