PC 5 lossed its map or other problem?
Old Jan 3, 2010 | 11:04 AM
thunderbob's Avatar
thunderbob
4th Gear
battery is ok, spark wires are ok, map is still in there...........huh still looking???????
Old Jan 3, 2010 | 05:55 PM
icewater103's Avatar
icewater103
Originally Posted by joesride
Check your battery out real good.Check the cables etc.Fuel pump will not run too good with bad ground or a slight film on battery cables.Cold weather can cause electrical type troubles with batteries, corrosion on connections and grounds etc. Check the easy things first. Good luck.
+1 I had a battery cable strand me on a short errand two hours after returning from a 150 mile ride. While waiting for a tow to arrive I found the problem. The battery cable would pull right out of the connector it had been crimped into by the factory down at the end that bolts to the starter. It looked fine otherwise and I had not had a problem before. I'd pull the seat off and give them all a slight tug if you haven't already and also make sure none are pinched.
Old Jan 3, 2010 | 06:56 PM
clicker01's Avatar
clicker01
Seems if the battery condition and connections are solid enough to allow starter engagement, the likelihood of it being the cause of a poor running engine is remote.
Old Jan 3, 2010 | 07:16 PM
thunderbob's Avatar
thunderbob
4th Gear
Found it, it was the damn power commander. It shorted out or something. I took it off and the bike is running fine.
Old Jan 3, 2010 | 07:49 PM
midnight2005's Avatar
midnight2005
I got caught in the rain with the pcV. It seemed like the pc did the same thing. I am going to have to check it out.
Old Jan 3, 2010 | 08:03 PM
skratch's Avatar
skratch
if you got it from fuel moto, they double the factory warranty to 2 years.
PHA-Q
Jul 21, 2011 09:56 PM
fatbob
Exhaust System Topics
Sep 29, 2010 11:25 PM
thunderbob
Jan 3, 2010 07:17 PM
BlockHead96
Nov 26, 2008 07:00 PM
gapwl3
May 15, 2008 04:06 AM
