Exhaust gasket on 2010 RK
Old Jan 26, 2010 | 06:05 AM
Sniper318's Avatar
Sniper318
Default Exhaust gasket on 2010 RK
Okay, I take my stock exhaust off while I'm waiting for my new exhuast to come in from Fuelmoto. I get the service manual so I will have the torque settings when I put the new pipes on...When I looked in the manual in the R/R it states to remove the gasket that goes from the exhaust to the head. I'm use to working on cars...I didn't see a gasket, is it compressed into the head? if so is there a trick to get it out? or was there no gasket? I don't want to jus start scratching things up to see if there is a gasket in the head.
Thanks in advance, Rob
Old Jan 26, 2010 | 06:37 AM
drjones's Avatar
drjones
There is a gasket in there. You can use a little tiny screw driver to pick it out. I use a machinist pick. They are mesh steel and hard to see because they contour to the port to prevent leaking. Good luck.
Old Jan 26, 2010 | 07:21 AM
WRAITH's Avatar
WRAITH
+1-Use a pick or small screw driver to remove the old gasket. Replacement gaskets are cheep.
Old Jan 26, 2010 | 07:52 AM
Hollywood Ball's Avatar
Hollywood Ball
Kinda funny, when I swapped the exhaust on my Night Train the biggest problem I had was figuring out where the gasket is and how to get it out.
As simple as it is, many people here are in that same boat. It's kinda funny.
Old Jan 26, 2010 | 09:55 AM
LugoMS's Avatar
LugoMS
So when you guys swapped exhaust was the gasket in the pipe or in the port?
Old Jan 26, 2010 | 10:01 AM
atrain68's Avatar
atrain68
Exhaust gasket will be in the port. I recommend the stock gasket over the screaming eagle gasket. The SE gasket sometimes does not seal the first time. Some people have luck with them, some don't. JMHO.
Old Jan 26, 2010 | 10:08 AM
atrain68's Avatar
atrain68
Sorry for the double post. I also recommend taking great care not to strip or cross thread the exhaust studs when you put the pipes back on. Consider getting a new set of exhaust stud bolts - they are cheap at the parts counter - and use anti-sieze before you put them on. Stripping or breaking these exhaust studs will be a nightmare.
If you have trouble inserting the new gaskets then spray them with WD-40. I read this in another post, tried it, and it works.
Old Jan 26, 2010 | 12:50 PM
Sniper318's Avatar
Sniper318
WOW...great help...thanks...I guess I will try a dental pick or something...I just bought two new gaskets from HD at $8.95 a piece. Yes the gaskets are pressed in the head and you wouldn't know they were there unless u knew they were there (?). Thanks for the help I will keep you all updated...should have my new exhaust in tomorrow.
Old Jan 26, 2010 | 03:18 PM
tmitchellof PG's Avatar
tmitchellof PG
I used a little grease on the outside of the new gaskets to help pop them back into place. At first you might think that the new gaskets are too big to fit.
It takes some patience to get them seated.
You have to be careful not to distort them while you are pushing them into place.
I used some needle nose pliers to pull out the old gaskets.
Tom
clayharley
Oct 23, 2013 07:06 AM
traildog
EVO
17
Feb 25, 2012 07:59 PM
wlibert
Apr 10, 2011 10:37 AM
JakesDad1
Mar 25, 2011 09:55 AM
deadreckoning
Shovelhead
Mar 26, 2009 02:35 PM
