Weird battery tender issue
Old Jan 28, 2010 | 04:57 AM
dog155's Avatar
dog155
A tender will not work if the battery is below 11 volts or has a weak or dead cell.
Old Jan 28, 2010 | 05:12 AM
Garemlin's Avatar
Garemlin
Called Deltran yesterday. They said it sounds like a faulty unit. I can send it back an they will repair or replace it. But they charge $11.95 return shipping. So I basically have to pay $20 to have this one covered under warranty. Or I can buy a new one for $30. What a rip.
Old Jan 28, 2010 | 08:03 AM
Apex Rider's Avatar
Apex Rider
Can you take it back to where you bought it for a refund/exchange ?
Old Jan 28, 2010 | 08:23 AM
schumacher's Avatar
schumacher
I'd just get a different one. Mine doesn't do that.
Old Jan 28, 2010 | 09:06 AM
Big Sled's Avatar
Big Sled
If the place you bought it won't exchange it thus you are stuck with it (the $20 postage is a barrier to sending it to Deltran), then I'd cut the wall plug off the end of the 110v cord and put on a generic replacement plug (watching to keep the same live, neutral and ground wire matches)... and plug er back in and see if it will work. (You did seem to describe earlier a prob that sounded like the plug might be internally bad.)
Old Jan 28, 2010 | 09:20 AM
jimsflh's Avatar
jimsflh
Also polarity will cause it to shut down if reversed.
Old Jan 28, 2010 | 10:52 AM
dynodon89's Avatar
dynodon89
Check to see if you have any voltage at the clips or the plug?
I have several Battery Tender JR's, some of them light up when plugged in, and some have to be connected to the battery, model changes I guess. In many years, I have only had one go bad, and Motorcycle Warehouse replaced it with a more expensive unit! I ran OVER that one with a car recently, but after straightening the chassis and cover it still works great.
Send it back where you got it or to Deltran.
twp98
Jul 4, 2020 05:13 PM
sanman4ever
Mar 10, 2016 04:40 PM
2ropes
Mar 31, 2014 06:10 AM
Falcon195
Jul 28, 2013 05:07 AM
bra$$monkey
May 6, 2011 06:55 PM
