Coil Problem
Old Mar 4, 2010 | 08:22 PM
knuckledraggers's Avatar
knuckledraggers
Stage IV
Default Coil Problem
I have a 2000 road king EFI. when i turn the ignition on i have power to the coil till the fuel pumps shuts off. when i hit the start button the power should return but dosent. i have replace the relays and still no power to the coil unless i turn the ignition off and back on and thats only till the fuel pump shuts off. any sugestions?
Old Mar 4, 2010 | 08:33 PM
Booey424's Avatar
Booey424
I had a problem with the wires that go TO the coil. Not the plug wires,but the leads that go TO the coil. They were too loose and would intermitently get power. I just crimped them and they stuck better
Old Mar 4, 2010 | 09:31 PM
CroK's Avatar
CroK
Your post didn't indicate if you had power thru the starter when you hit the starter button. Does the engine actually turn over or do you lose power when you attempt to engage the starter?
Double check all of the connections starting from the battery on out to the coil. Check the battery too. Also, the ignition switch itself can be disassembled, and contacts cleaned. I recently had an intermittent problem with the switch. Once I cleaned the contacts all is good.
Doug Fogleman
EVO
17
Jul 3, 2021 07:28 AM
afraziaaaa
Oct 23, 2017 07:14 PM
?roadking?
Nov 12, 2012 01:45 PM
mekanikmm
Jan 19, 2009 08:34 AM
harrygart
Dec 15, 2007 05:32 PM
