Technical question about strange noise...
Old Apr 2, 2010 | 05:28 PM
TFTCAR's Avatar
TFTCAR
Smile
If it is the same clunk I am thinking about you are not the first one to experience it. You will find if you search this forum you will find a fix for the the dreaded steering stem nut clunk. On mine a little scuff of emery cloth under the nut and the updated torque of that nut and all is cured. Hope this helps.
Old Apr 2, 2010 | 05:39 PM
scubadnv's Avatar
scubadnv
Don't forget to pay close attention to the brakes, it is possible that something in that system like rattle clips or even mounting blots can cause a noise like you describe. While riding over a spot where you can duplicate the noise, try to lightly pre load the brakes one at a time and if the noise goes away then closely inspect that area. Good luck!
Old Apr 2, 2010 | 06:06 PM
BLKBAGGER's Avatar
BLKBAGGER
I had a problem like this before and I finally figured out that it was my shocks topping out. The wheel would drop into pot holes and the shock would extend all the way and top out. made a hell of a banging noise. I only found out after i changed out the shocks for better ones.
Old Apr 2, 2010 | 07:45 PM
harleydavis's Avatar
harleydavis
+1........you can also adjust the pre-load on the shocks to firm up the ride to keep from bottoming out.
Old Apr 3, 2010 | 05:32 AM
99octane's Avatar
99octane
Checked brake calipers and belt cover as well. Tried to rattle the gas tank, but it seems pretty well fixed.
Jumped up and down on the bike like a mad ape on meth, without any rattle. Both rear shocks and fork.
I'm narrowing this down to two main suspects: steering head and engine elastic support.
Suspect N° 1 right now is steering head bearing...
Old Apr 3, 2010 | 06:59 AM
mudsweatNgears's Avatar
mudsweatNgears
My jifffy stand made a helluva loud rattling noise when decelling. The rubber pad on the frame had spun and it was rattling on the frame. Coulda swore it was a bearing gone south somewhere.
Old Apr 3, 2010 | 08:28 AM
gman's Avatar
gman
Originally Posted by stvn22
Same on my FatBob
had the same clunk on my '06 WG. replaced the steering head washer with no change. I finally discovered that the bolts securing the fuel tank were loose.
Old Apr 3, 2010 | 08:37 AM
99octane's Avatar
99octane
Did the fuel tank move if you tried to lift or shake it by hand (I tried this on mine and seems solid)?
Old Apr 3, 2010 | 08:42 AM
gman's Avatar
gman
when the tank has fuel in it, it is pretty heavy so you might not be able to easily move it around. how i finally found the problem was to find a bump in the road that caused the clunk, then i ran back over the bump and squeezed the tank between my knees. this eliminated the clunk, so i knew then that the problem was with the tank mounting. i'd just tighten the two bolts, front and rear, and see if this helps.
fooschamp
General Topics/Tech Tips
Aug 11, 2017 02:50 PM
Sedonastrider
Sep 22, 2016 06:04 PM
jp13
Jun 6, 2016 10:35 AM
violentj
Aug 1, 2012 02:51 AM
Ironhorsepilot
22
Jun 10, 2009 10:37 AM
