Cleaning Spark Plugs
Old Apr 9, 2010 | 09:24 PM
kc5gxc's Avatar
kc5gxc
Smile Cleaning Spark Plugs
Reading the plug posts and am wondering how you guys clean your plugs? I generally just wire brush with a small brush and check the gap with feeler gauge. Wonder if causing damage with wire brush on electrode tip? Are you supposed to use a wire gauge instead of feeler gauge?
Thanks, Pete
Old Apr 9, 2010 | 09:41 PM
2kids3pets's Avatar
2kids3pets
wire gauge is meant for plugs..I have a can of intake cleaner, it it removes all the chit off the plugs without brushing. back in the day we used a small sand blaster set up to clean plugs
Old Apr 9, 2010 | 09:54 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Plugs are like $2.25 at my dealer.....I just put a new set in every other year.
Old Apr 9, 2010 | 09:57 PM
useR 564357348's Avatar
useR 564357348
Thanks, Pete
You shouldn't need to clean plugs if the bike is set up properly, however, plugs can break down relatively quickly. I replace them approx. every 5000k miles instead of cleaning them since they are relatively cheap and on a V-Twin fresh plugs feel good.
Old Apr 9, 2010 | 10:12 PM
clicker01's Avatar
clicker01
I don't know what year it started, but the recommended replacement interval is 20,000 mi. as of 09, . I replaced mine at 10k, but my indy's older manual showed them at 10k.
They came out bright white thanks to the severe lean running condition these bikes come out of the factory with. Waiting on fuel moto to arrive to put an end to that.
Old Apr 9, 2010 | 10:14 PM
krusty1's Avatar
krusty1
Plug condition is really more of a diagnostic tool....replacement is cheap, but the tale they tell is of far more importance. In fact, a fresh set of plugs tell a much more obvious story.
Old Apr 9, 2010 | 10:28 PM
DannyZ71's Avatar
DannyZ71
This guy just swishes them around in his mouth.
Old Apr 9, 2010 | 10:39 PM
dope_man_21's Avatar
dope_man_21
If I take mine out, I throw them away and install new ones. There are cheap enough that I would not even try to clean them, unless I was stuck on side of the road somewhere and had a problem with them.
Old Apr 9, 2010 | 10:44 PM
SportsterBob's Avatar
SportsterBob
Hell, I'm using the same plugs in the B-T from 2007...Don't need to clean them!
Now the Sporty is another story...I carried 3-sets of plugs when riding that cantankerous beast!!!
Old Apr 9, 2010 | 10:59 PM
harleydavis's Avatar
harleydavis
+1......then I would go to a Kragen or O"Reilly and buy some new Champion plugs for $2.00+ each.
