2007 upgrades
Old Aug 12, 2006 | 05:37 AM
Josey Wales's Avatar
Josey Wales
Default 2007 upgrades
Well I must say there is a lot of talk on this subject but nobody seems to know what the official word is! I have heard that you can add the stage 1 upgrade and that the new ECM will automatically adjust accroding to the upgrades ( Which makes sense, all new automobiles will do that I just put a new borla cat back and air cleaner assy. on my truck and it said in the instructions to pull my ECM fuse to reset it and it will automatially make the neccesary changes) and I have also heard different! I think I might wait to do the stage 1 until next spring on my night train when I will have more options and somebody will know WTF is going on!
From the famous words of Master Po: You must have Patientce Grasshopper!
Old Aug 12, 2006 | 08:22 AM
dawg's Avatar
dawg
Default RE: 2007 upgrades
If that were the case I would think they would run into trouble with the EPA. I would also think that it would be hard to come up with a resettable ECM that could detect what you have for a set-up. It would be cool though if all came through automatically with a programmable ECM that could be tweaked with different maps in the first place!
Old Aug 12, 2006 | 01:29 PM
bay13's Avatar
bay13
We need to get the local tech to fill us in on how the new ECM works.
Side note: On say the 1996 Volvo, the O2 sensors have direct input into the duration the injectors are actually opened. But.............. when you go above 4K then a pre-determined map in the ECM takes over, hence the need to be tuned even though you have O2 sensors. I don't know if this is how the HD ECM works, there are lots of options so without input from someone "In the Know" it's all guessing.
Old Aug 12, 2006 | 03:12 PM
nidan's Avatar
nidan
The stage 1 and 2 103 kits require a reflash of the ECMs according to the 07 P and A catalog
Old Aug 20, 2006 | 04:36 AM
eveoengine's Avatar
eveoengine
Harley has the stage 1 download available now along with se mufflers and breather. The 02 sensors on Harleys are narrow band, cars are wide band, therefore Harleys will change very little.
Wardog86
Mar 28, 2013 01:07 PM
rs03371
Mar 26, 2013 09:40 PM
96roadking
EVO
Mar 27, 2010 05:41 PM
King_O_Road
Exhaust System Topics
Sep 21, 2008 11:43 PM
gdbro4
Nov 28, 2006 11:07 PM
