Help!!! (please) Stuck in Paso Robles
Old May 3, 2010 | 01:38 PM
Thatzmister2u's Avatar
Thatzmister2u
Default Help!!! (please) Stuck in Paso Robles
On a trip with wife. Bike fires right up this morning. Head to gas station to top off. Won't start. Already checked battery connections. Fuel injection charges. Faint click from left side cover when hitting ignition switch. Pulled fuse box but can tell if starter is blown. No turn over. Light, radio work. Suggestions?
Thanks so much!
E-
Old May 3, 2010 | 01:40 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Try pushing the relay in with the fuses in a little further. Or, remove it and put it back in. Also could be the battery with the clicking you describe. Gary Bang HD is nearby. Here is their number. (805) 461-1818
Old May 3, 2010 | 01:42 PM
Thatzmister2u
Dr V-Twin already removed and re-seated. Thank you for replying!! There is a wal$art here, think I can find a fuse?
Old May 3, 2010 | 02:01 PM
qtrracer's Avatar
qtrracer
Have had that happen before and it was the battery, I mean exactly that same scenario, fired up first thing, stopped for fuel and a light click. Battery was bad.
Old May 3, 2010 | 02:04 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
You should be able to find a fuse in Wal-Mart. Is one of your fuses toast? If so which one?
Old May 3, 2010 | 02:16 PM
Thatzmister2u
The bike started. Last thing I tried was wiggling the wires at the started but they felt rock solid. Don't know if it was the wires or the battery sitting. Gary Bang is closed today. thanks for responding! Came back to hotel before trying a restart. Having a cold coke and then we will see!
Old May 3, 2010 | 02:17 PM
Thatzmister2u
I was looking at the started relay fuse and no they didn't have one at walmart.
Old May 3, 2010 | 02:19 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Could be loose starter bolts too then.
Old May 3, 2010 | 02:20 PM
Thatzmister2u
I will check them. Thank all of you for responding. I will provide updates as they happen!
Old May 3, 2010 | 02:23 PM
Kims toy's Avatar
Kims toy
That sounds like battery is toast!
Had same thing happen to me.
Also guy at work.
If it's 4 or 5 yrs old, it needs replacement.
Good Luck!
Kim
