Wanted to make a cool ride for my son. Started with an old '74 sportster that I had kicking around for 30 something years.
I got a set of 8 over fork tubes. I raked it out long and low ( no stretch ), as he is tall like me. Looks cool, but has some ill effects. The trail is 10". Very difficult low speed manuvering, even more so than if I just stretched the downtubes. Had to push the gas tank way back, had to alter gas valve , drag bars contact tank, etc.
Now I want to make it a hard tail. The weld on and bolt on rears just aren't doing it for me. Looks really stupid now that I really played with the geometry.
I am considering just abandoning the frame and going for a manufactured hard tail.
My question for the geometry pros out there is:
To use the 8" over tubes, and to keep the 19" wheel, what stretch & rake numbers should I be looking at, to keep the bottom tubes and engine level?
Rather than do the calcs you can line up a side profile shot and use photoshop to mess with the geometry (cut/turn/paste) until who have what you really like, then work back with centrelines to arrive at the measurements. Done it a few times and you can get within a knat's **** this way. Use a long focal length to minimise paralax.
Try a set of 5 degree raked trees. That should pretty much fix the low speed handling problem. I ran a '72 XLCH with 7/8" rake (probably about a total of 45 degrees) and 15" over tubes. Low speed handling was of the "Give Me 40 Acres & I'll Turn This Rig Around" variety.
