Headlight trouble....
Old Aug 23, 2010 | 08:40 PM
Dan0's Avatar
Dan0
Default Headlight trouble....
I wanted to go for a ride this evening but when I fired up my bike the headlight was out. I checked the fuse (it was good) I pulled out the bulb and I jumped it with some wire and a battery (the bulb is good) Is there something else I can check before I bring it to the shop?
Old Aug 23, 2010 | 09:32 PM
midnight2005's Avatar
midnight2005
get a 12 volt test light and test the plug that goes to the bulb
Old Aug 24, 2010 | 07:01 PM
Dan0's Avatar
Dan0
Ok, I tested the plug...no fire. I tested the fuse and I do have fire at the fuse. Looks like I will have to pull off the tank and start ohming wire
Old Aug 24, 2010 | 07:06 PM
soft 02's Avatar
soft 02
before you do that move the fuse around and see if the light comes on or remove the fuse block all togather and see if you have continuity through the back of the fuse block. If so then move on to removing the tank. I just went through this and I had a lot of corrosion inside the fuse box but could not see it from the outside. Good luck.
crawrj
Sep 22, 2014 07:05 AM
grlflh
EVO
Aug 13, 2012 08:40 AM
Stevieskull
Nov 17, 2011 02:19 AM
7westwill
Aug 2, 2011 09:18 PM
BlackHwk27
Aug 5, 2009 07:35 PM
