Nitrogen
Old Sep 10, 2006 | 09:31 PM
SMenasco's Avatar
SMenasco
Default Nitrogen
Anyone running nitrogen in their tires? Any truth that it will remain at pressure with no fluctuation?
[IMG]local://upfiles/1638/BF5C6552A07A4F34866034CB9D61FE09.jpg[/IMG]
Old Sep 10, 2006 | 09:42 PM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
Default RE: Nitrogen
It will still build pressure as the tires heat up, but will be more consistant as there are less impurties like water ect, that you have in compressed air.
Old Sep 10, 2006 | 11:55 PM
Tim's Avatar
Tim
Is it really worth the extra effort? Tim
Old Sep 11, 2006 | 12:28 AM
KeithB's Avatar
KeithB
ORIGINAL: Tim
not for the street
Old Sep 11, 2006 | 12:55 AM
bobcowan's Avatar
bobcowan
For a variety of reasons nitrogen does not expand when it gets hot like air does. On a race car, that's a good deal. As the tires heat and cool, the presssures riand fall. That changes the suspension a considerable amount. In a racing environment, 2psi makes a huge differance.
On the street, its a whole differant story. First, nitrogen is hard to come by on the road. If it's just a local commuter or bar hopper bike, you could make it work.
Second, to obtain any benifits you have to be sure that the tir contains pure nitrogen. not other contaminants. Not too difficult to do with a tubed tire, but nearly impossible with a tubeless unless you also spring for the expensive equipment.
Third, when a tire maker recommends a specific pressure, that's a cold pressure. The tire maker knows that the pressure will increase as the tire gets hot. With nitrogen only, the tire won't perform as expected or designed.
Old Sep 11, 2006 | 10:54 AM
JerrySC's Avatar
JerrySC
There is nothing wrong with servicing tires with nitrogen. For a bike, there is no advantage to it either. Some aircraft tires use DRY nitrogen for tire servicing to eliminate the possibility of water freezing in the tire at altitude and to help with fire supression in a "hot brakes" landing scenario. Air is 70 percent nitrogen anyway.
Old Sep 11, 2006 | 10:56 AM
mikec's Avatar
mikec
78%
Old Sep 11, 2006 | 12:01 PM
huffhuff's Avatar
huffhuff
nitrogen molecules are larger than "air"so less leakage and load bearing capability is increased, the tires run cooler at speed so wear is reduced. it's worth it and you won't much trouble finding a dealer with the nitrogen equipment.
SpringerRider
Mar 8, 2018 03:18 AM
kneichko
Sep 22, 2012 10:41 AM
iride1
Mar 18, 2012 05:01 PM
trailey97
Mar 26, 2010 12:08 AM
joetoyc
Sep 22, 2005 12:02 PM
