What's proper way to use a lift?
Old Sep 28, 2010 | 12:02 PM
grgerman's Avatar
grgerman
Default What's proper way to use a lift?
I am new to biking and have just purchased a Sears Professional aluminum motorcycle jack. The directions say to strap the bike to the jack after lifting by placing an included rachet strap over the seat.
I am afraid this may harm the seat and also that it is not the most secure approach.
How do you experienced guys do it? Strap to handle bars, frame, ??
Thanks in advance.
Old Sep 28, 2010 | 12:09 PM
Blue SOG's Avatar
Blue SOG
I don't use a strap with that jack. If I'm going to be doing something that would require the bike to be strapped down then I use a table lift or I'd set the frame on blocks using the jack...
Old Sep 28, 2010 | 12:19 PM
Hollywood Ball's Avatar
Hollywood Ball
I have a jack that is similar to this one, but haven't had the need to strap down. If you're worried about the seat, take it off, throw a towel on the frame rails and just strap over the frame.
Old Sep 28, 2010 | 12:23 PM
CruzN's Avatar
CruzN
Default Handlebars
Thanks in advance.
I never use a strap on handle bars, they will bend.
I don't like leaving the bike up as high as you have to get the jack in the safetly locked position so I use straps. I place a towel on the seat, run a strap from the left passenger peg over the seat to the right side of the lift. Repeat for the other side which crisscrosses the seat. Just adds piece of mind for me.
Old Sep 28, 2010 | 12:46 PM
jimmers1817's Avatar
jimmers1817
Get a J&S jack and you won't have to worry about straps. Solid as a rock.
Old Sep 28, 2010 | 12:52 PM
Iceman24's Avatar
Iceman24
Although you already have the Sears jack - never had to strap my J&S. Roll it all over the garage w/no problem(s).
Old Sep 28, 2010 | 01:15 PM
El Dee's Avatar
El Dee
Default The evel one
Personally I favor my Pitt bull jack.They're the best dog and jack IMO. That said I've got no experience with the Sears jack. The most important thing when jacking it up will be balance. Find your sweet spot that's clear of such items as pipes/kickstand, jack her up a bit and watch to see that the tires lift somewhat evenly. Given the front and rear suspension may not allow both tires to be even get them both clear and test your balance. Make sure it's not gonna kick the jack out and fall off. Be prepared for a major change in balance if removing a tire. I don't use straps as the Pit Bull is wide and stable. I also try and get it as far forward as possible. The engine should be somewhat centered on the jack for the balance to be correct. Just give her a go and find the spot on the bottom of the frame where the bike is well balanced. Straps can't hurt so use them if it makes you feel better. I'd also remove the seat and try to hook it instead of running it over the bike. I have a set of soft ties so no damage will occur when strapping her down. Good Luck.
Old Sep 28, 2010 | 01:31 PM
Clayvis's Avatar
Clayvis
I have a jack similar to the Sears Jack. I got mine at Harbor Freight Tools. On my Softail, I use rubber frame protectors (got them from a local Harley $tealer) to keep the jack off the shocks. I only strap it down when removing the back tire. I run the straps around the frame to avoid damaging anything. It makes me feel safer. Don't want a 710 lb bike falling on me...It might damage the chrome parts!
Old Sep 28, 2010 | 01:32 PM
2kids3pets's Avatar
2kids3pets
How mine was strapped for some surgery
Old Sep 28, 2010 | 01:42 PM
brenn's Avatar
brenn
I park the bike between the uprights of my weight machine and strap it to that from each side. Much more stable than strapping it to the jack.
