Charging problems
Old Oct 16, 2010 | 10:03 AM
richard 58's Avatar
richard 58
Stage III
Default Charging problems
I have a 92 ultra when iam at idel my volt meter reads 10 volts when iam runningits charging fine but when i turn on my turn signals it it jumps back and forward when i stop my turn signals stop working. I have changed the stator, regulator, and battery can somebody help
Old Oct 16, 2010 | 10:07 PM
Steve On 3's Avatar
Steve On 3
Had a similar problem with my 95 Ultra. After following every wire from the battery forward, I finally found the culprit. Remove your headlight and fairing ( probably can check without removing the fairing but it's easier removed). You will have a wiring harness coming along the right side of the frame by the tank and into the fairing. It will have 3 large red wires on it if I remember. The connector for that harness os to the left side of the fairing bracket as you look at the bike from front to back. The connector is large and flat. Clean the contact points and make sure it is making good solid contact there.
I was getting good voltage out of the stator, good voltage to teh circuit breaker under the seat but not good voltage to the fuse/circuit breaker bus under the fairing. After cleaning and re-installing, my problem went away. I'll bet yours might too.
Good luck
Steve
Old Oct 16, 2010 | 11:34 PM
hatchetman's Avatar
hatchetman
Mine is the same. usually a crappy connection to the gauge. I tested at my battery with a volt meter & it read awesome so I dont worry about it!
Old Oct 16, 2010 | 11:40 PM
BB4xl's Avatar
BB4xl
+1 on what hatcman said. Don't trust the gauge to be accurate, especially as they get older. Check it with a meter. Its normal for the gauge to jump with the turn signals. I only have a 32 apm system. Not sure what yours would be.
Old Oct 17, 2010 | 05:19 AM
shortride's Avatar
shortride
It best to use Dielectric Grease on connectors. You will neve have another problem with the connectors that you use it on.
Old Oct 17, 2010 | 06:08 AM
artz's Avatar
artz
I've learned alot of the time, its just a little hidden corrision under what looks to be clean medal on top. You gotta slow down and search a little closer.
Start off with where you store or park your bike. Do you ride in the rain alot ? etc.
Old Oct 17, 2010 | 09:06 AM
richard 58's Avatar
richard 58
Stage III
Thanks for the info, I will try looking for a bad connection it is a 32amp system Thanks again
Rich
Patches513
EVO
14
Dec 1, 2018 08:20 AM
tchopper1969
Electrical/Lighting/Alarm
May 4, 2015 09:39 AM
Lingleha
Jul 8, 2012 06:07 PM
johnpaul
Jun 26, 2012 08:48 PM
my first harley
Apr 10, 2011 04:48 PM
