Air Compressor Question?
Old Nov 3, 2010 | 12:46 PM
oct1949's Avatar
oct1949
I've had a 20gal with real pistons, not the diaphragm type for 30 some yrs...
It will handle air power tools with its 6.7 CFP at 90psi,
A smaller one just won't keep up with most air powered tools.
Old Nov 3, 2010 | 12:54 PM
gasol1ne's Avatar
gasol1ne
I have a 240V, 80 Gal, 5hp, 2-stage unit. Craftsman Professional. I'm not an expert, but I did a fair amount of research before I bought it and found several folks who stated that the oil-less kind are not a good choice. That may only apply to larger units, and it may be that all of the smaller units are oil-less, but I wanted to let you know. Craftsman makes nice compressors, among many others. CFM is the big number to look for, generally speaking, if you may run tools with it.
Old Nov 3, 2010 | 01:27 PM
fixedmlc's Avatar
fixedmlc
What is the problem/complaint with the oilless compressors? I just bought a 2 gal/100psi pancake one for airing up tires and blowing dust off stuff.
Old Nov 3, 2010 | 01:59 PM
nytryder's Avatar
nytryder
Oilless compressors are noisy as hell. If you do buy one READ the break in instructions. Most will tell you to run the new compressor 30 min with the tank drain valve open.
Old Nov 3, 2010 | 02:03 PM
fixedmlc's Avatar
fixedmlc
Did that yesterday
Old Nov 3, 2010 | 02:16 PM
CroK's Avatar
CroK
I have an industrial 3 phase unit that I converted over to 14HP gas engine...
It has an 80gal tank, with 1.25" outlet. This is a BEAST! Don't remember the CFMs, but you could push your MC across the street with it! That is overkill, for most DIY'ers...
I also have a small pancake compressor I bought as a kit, with 3 nail guns, made by Porter-Cable. You can get these at most Home Depot or other building supply. (Harbor Freight has a copy with 150psi). I believe the out put is around 12cfm, 135psi, 3gal tank. I use this one almost exclusively working in my shop. Runnin air ratchets, impact guns, and air hammer. The low cfm and volume insists that I wait for it to build up now and then, but it isn't that inconvenient. I even remove my compensator nut/mainshaft pully with it. The output is not sufficient to blowdry the bike. I use my 5hp shop vac (in reversed mode) for that..
It all depends on YOUR needs. Easy to say you'd be better off doin this or that, but if you'll never be doin production work, many of the smaller units may serve you well...
Old Nov 3, 2010 | 02:37 PM
user 8373900's Avatar
user 8373900
The bigger the tank, the less you have to listen to it run.
Mark
Old Nov 3, 2010 | 02:43 PM
SMF's Avatar
SMF
+1 on the pawn shops i got lucky got mine at base it was on sale with all the tools and lines for 350
Old Nov 3, 2010 | 03:30 PM
jthom33's Avatar
jthom33
I have a Craftsman 30 gal, oilless. I use it a couple times a week, wrenching on cars, blowing the garage out. Wouldnt use it for drying the bike. Use a shop vac on reverse. If you're lively hood relies on it, go big. If its just tinkering, check craigslist or pawn for a Craftsman or Harbor frieght.
Old Nov 3, 2010 | 03:40 PM
TheJimer's Avatar
TheJimer
Originally Posted by IAMSWUTIAMS
a large tank is important ,more important is how many cfm's it puts out if you want to run tools .
+1 on the CFM's. Also the larger the tank the less the compressor will have to kick on.
Jim
