If you don't go with a bigger one,yoou'll have 2 compressors next year, the small one you bought now and the one you should have bought to begin with. (I have 2). Do craigslist got a nice one for 100.00.
I bought the 12 gallon sears one a couple of weeks ago, I don't do alot of stuff that would require a compressor, I did my g/f's sons brakes and it was suitable for pulling the lug nuts and the bolts out of the caliper, it did turn on a fair amount, but it got the job done.
That 90 dollar one will not operate air tools. Airing up tires and blowing dust off stuff is what it's good for. I don't have any air tools, but know from using one of those little ones what it's good for.
For drying my bike after washing I use a small electric leaf blower I found at a yard sale for 3 bucks.
Just used my little 3 gal oilless 100psi compressor to fill tire on the sportster (did a great job), and then set pressure in the tires on my truck to 66 psi. Did a great job, I don't mind the compressor running, or having to wait a second for it to come back up to pressure.
Don't buy an emglo unless its above 50 degrees. Mine won't start unless its 60 degrees out. A 20 gal , 3 HP compressor is perfect. Enough cfm for blowing air for drying. I have Speedair that I got from Grainger for $400 12 yrs ago. I just replaced the check valve for $11 and the pressure switch for $30. I use it for my framing guns, HVLP spray guns in shop, air ratchets and air impact gun. I fill my big front end loader tires too ( although only 20lbs) The impact gun takes allot of CFM, the little compressor will not handle it, trust me, I have been building houses for 25 yrs.
It'll work for me!
great for blowing up party balloons, bicycle tires & light duty gadgets............just not enough for running air tools & whatnot..................
Funny, mine worked at 20F in Park City Utah. I've been framing since 1973
