Harley Tech's opinion needed for engine question
Old Feb 1, 2011 | 01:37 AM
oct1949's Avatar
oct1949
Said I report back... Bout my Friends 10 ultra with 3.5 k on her
My friend called today and said they so far have check out the Cly'ers and found the rear cly plug is fuel and oil soaked......
Said the ECM is out of wack and dumping fuel in it.. Also excessive oil in the Exhaust .
They are tearing into futher tomorrow.
Old Feb 1, 2011 | 09:54 AM
1931jamesw's Avatar
1931jamesw
You've got my attention, I wanna know how this turns out.
Old Feb 1, 2011 | 01:55 PM
oct1949's Avatar
oct1949
I am still thinking this is a rare issue not a common problem..
Old Feb 1, 2011 | 02:03 PM
Hocus-Pocus's Avatar
Hocus-Pocus
Originally Posted by EW1959
I just found the receipt for the work done on the bike when the seals were repaired. It had 4660 miles on the odometer and maybe 400 miles later had the 5k service. It now has 6060 miles and the oil dosen't touch the stick. I'm thinking the seals were not the problem. The bike doesn't leak oil or smoke.
If the bike doesn't leak or smoke, where do you think the oil is going? It's got to go somewhere. If the valve guide seals where bad, the motor has got to be smoking otherwise, it would be leaking the oil.
my .02
Old Feb 1, 2011 | 02:09 PM
arcticharleyman's Avatar
arcticharleyman
If you can't SEE the oily smoke, just try wiping your finger around inside the exhaust. If you get an oily residue, you are burning the oil.
BTW..is the bike on the jiffy stand or upright when you check the oil?
Old Feb 1, 2011 | 04:41 PM
EW1959's Avatar
EW1959
Harley tech tore into the motor and found a bad valve guide and the piston rings on the back cylinder were turned the same way, allowing the oil to seap thru the rings. The shop manager replaced the valve guide seals earlier. He told me he checked rings and everything and put it back together. Anyway it's their problem now since I traded yesterday for a Road King Custom.
Old Feb 1, 2011 | 07:08 PM
Hocus-Pocus
Any oil that's getting into the cyl while the motor is running is coming thru the bad valve guide and, is being burned. Hope you have better luck with the RK
danh@bowerspower.com
Milwaukee Eight (M8)
44
Jun 5, 2019 06:18 PM
JPL
Sep 7, 2011 06:52 PM
SmokerMI
Oct 2, 2008 10:57 AM
glide05
Oct 22, 2007 06:37 AM
Hog_fever
Jun 27, 2006 01:11 PM
