Cutting Down Windscreen
Old Jan 30, 2011 | 06:45 PM
MikeK02048's Avatar
MikeK02048
Default Cutting Down Windscreen
I'm pretty close to buying my first HD, a new Road King Classic. I'm 5'7" and the windscreen is too tall for me. I'd rather look over it than through it. I thought I'd have to buy a shorter windscreen but a salesman at the dealership said I can take it to a glass cutter and have it cut down to whatever size I choose.
Considering it's not really glass but Lexan, is this a good idea? Anyone do this?
Old Jan 30, 2011 | 06:55 PM
Other Sheep's Avatar
Other Sheep
I did it to my 99 Heritage. Tape it off where you want to cut it. Put a second layer of tape to prevent scratches from the saw. Use a quality scroll (jig) saw with a fine blade and take your time. It's not difficult. Sand the edges a little when your finished cutting and nobody will know you cut it. Or spend a hundred dollars or so for the size you want.
Old Jan 30, 2011 | 07:00 PM
BassCatcher's Avatar
BassCatcher
I cut mine down two days after I bought her. There is a very exact procedure to follow along with a youtube video. Lot of guys here have done it as well, but follow the directions. Do a search and you will find all the info you need.
Old Jan 30, 2011 | 07:04 PM
barjbar's Avatar
barjbar
I paid a business that manufactures boat windscreens $25 and they did a great job. If you don't want to do it yourself, call a glass repair facility and ask them if they do it themselves or can refer you to a company. Most dealerships also know companies that can do the work. It's not supposed to be that difficult but I have no experience and I didn't have the type of electric saw required.
Old Jan 30, 2011 | 07:21 PM
Tom T-Bird's Avatar
Tom T-Bird
I have done it myself. Just like Other Sheep says. Masking tape where you want to cut. I used a band saw with a fine blade that was for meant to cut balsa wood. Draw a line to follow, this will make for a better cut. Pull the tape and sand the edge with a fine grit sand paper.
Old Jan 30, 2011 | 08:13 PM
deadhawg's Avatar
deadhawg
Exactly what I have done several times on different bikes, works fine, just take your time, if you go too fast the saw blade will melt the lexan.
Never tried it with a glass cutter, I doubt it would work.
Old Jan 30, 2011 | 08:23 PM
DCLXVI's Avatar
DCLXVI
I cut mine no problem. Finished the edge with sand paper. Looks great.
Old Jan 30, 2011 | 08:25 PM
foxhd's Avatar
foxhd
I've cut several with a coping saw by hand.
Old Jan 31, 2011 | 12:55 AM
oct1949's Avatar
oct1949
yeppers cut mine bout 3''
theirs been a bunch of threads on how to...
I used a roto-zip,, worked for me, like cutting butter.
Other use saws of all kinds.
Will say after the third yr the coating starting peeling a little bit in one area along the cut line. its bout 3 inch half circle.
Old Jan 31, 2011 | 12:59 AM
BoomerBob's Avatar
BoomerBob
A lot of folks, after taping off the shield, get a piece of cardboard and trace the original top of the shield, cut the cardboard along the line, and trace it onto the tape to get that same smooth arc.
