#$%#@@! v&h baffles
Old Oct 7, 2006 | 02:32 PM
Rhubarb's Avatar
Rhubarb
Default #$%#@@! v&h baffles
Got my new quiet baffles for my V&H Longshots.
Looked like an easy 10 minute job.... HAH!
Following their instructions, I went to remove the retaining screw... what retaining screw?!?!? Oh, I can see it... Under the heat shields.
V&H said they were exposed through the shields. I guess they forgot to put the access holes in [:@]
Great. Take all the clamps off, shields still wont come off like they say they will.
Ended up having to pull the pipes back off that I had just put on a week ago after spending an hour trying to get the shields off.
Anyhow, a 10minute job turned into a 2.5 hour job.
Good news is the sound seems much more controlled and livable for me.
Thanks, I feel better now.
[sm=biker2.gif]
Old Oct 7, 2006 | 02:36 PM
softail2005's Avatar
softail2005
Default RE: #$%#@@! v&h baffles
I bought the quite baffles too but never installed them. I have gotten used to the open pipes, although my neighbors haven't. I love the sound in the valleys and woods of Oregon.
Is there a big difference in the baffles and did you have to reset you EFI?
Old Oct 7, 2006 | 02:44 PM
anubisss's Avatar
anubisss
The important part is that you got it done. Who cares how long it takes. It's kinda like when you get driving directions on line for me. If it says 30 minutes, I assume an hour and a half in a car. What's the rush anyway? Oh, you wnat to ride it? LOL. But it is done now.
Old Oct 7, 2006 | 03:29 PM
Rhubarb's Avatar
Rhubarb
ORIGINAL: softail2005
As far as I can tell, they sound much more tame. Lower note (no rasp), and a bit quieter.
Gimme a couple days to see.
I need to program my EFI, but I haven't yet. As soon as I installed the pipes, I knew I would want the quiets, so I ordered them shortly after.
I will be placing an order with FuelMoto on Monday for a PCIII. Talked to Jamie there and he will set it up for the quiets, and fuel economy. He said there was a difference in programming for the different baffles so I should wait until I figure out which ones I was going to keep.
The std baffles are straight through with louvers inside.
The quiets have what looks like an engine freeze plug welded to the leading edge and fiberglass wrap around the baffle. No louvers though.
Old Oct 7, 2006 | 06:01 PM
PosseRider's Avatar
PosseRider
What do they charge for the quiet ones? I think I want mine a little softer also.
Old Oct 7, 2006 | 06:10 PM
Rhubarb's Avatar
Rhubarb
Bought mine from CycleSpot for $26 each.
They did some sound tests you can look at on there, as well as they guarantee'd they would fit in the standard longshots. V&H said they would not.
This is the link to the baffle tests http://www.cyclespot.com/baffles.html
Old Oct 7, 2006 | 07:07 PM
PosseRider's Avatar
PosseRider
Thanks for the link. Gonna check it out now.
Megadeath
Exhaust System Topics
Nov 4, 2013 05:58 PM
CyclChyc
Jul 18, 2009 07:20 PM
Professor
Mar 1, 2008 08:01 PM
ladodgerdog
Sep 10, 2007 11:30 PM
RMBob
Sep 15, 2006 12:54 PM
