Bearings
Old Mar 5, 2011 | 04:20 PM
jslenk's Avatar
jslenk
1st Gear
Default Bearings
How do you change rear wheel bearings on a 09 nightrain
Old Mar 5, 2011 | 08:28 PM
ogh11756's Avatar
ogh11756
Not trying to be negative but the service manual for your model year bike is full of priceless info like what you are looking for.
Not really expensive either.
Old Mar 5, 2011 | 08:35 PM
FroggyFatBoy's Avatar
FroggyFatBoy
very carefully...
agree with the above post.. get a manual for complete directions and pictures... pictures are always best.
Old Mar 9, 2011 | 06:17 PM
jslenk's Avatar
jslenk
1st Gear
Just have a back wheel don't want to buy manual just for the wheel.Using it on a different bike just need to change bearings.
Old Mar 9, 2011 | 07:24 PM
trozenhorse's Avatar
trozenhorse
bearing puller, harbor freight has inexpensive ones, or georges garage, its a blind puller, you can find info on youtube.com
Old Mar 9, 2011 | 08:07 PM
Mikey 1450's Avatar
Mikey 1450
If you install new bearings, the bearings must be spaced correctly, I urge you to read up on this before you get started.
Old Mar 10, 2011 | 07:20 PM
jslenk's Avatar
jslenk
1st Gear
Thanks
Old Mar 10, 2011 | 07:24 PM
DaddyKnuck's Avatar
DaddyKnuck
When I need to change new style bearings I borrow the special puller from Advance Auto Parts. No charge, you leave a credit card imprint. The bearings should be pressed in (if you have a big enough arbor press.) If not a bike shop will do it for a couple of bucks. There is an order to the bearings being installed. I don't remember which goes in first, but it's pretty obvious when the bearings are out.
Old Mar 10, 2011 | 08:03 PM
TwiZted Biker's Avatar
TwiZted Biker
Why are the bearing being replaced so soon on such a newer model bike ? Not being a smartass here please but I've been hearing a lot about the newer sealed bearing going out fast and I'm curious about this , being a mechanic I all about knowing the why behind any failure or replacement .
Old Mar 10, 2011 | 08:32 PM
golfblues's Avatar
golfblues
Read post #4
