Best route planning tools?
Old Mar 7, 2011 | 11:16 AM
inswva's Avatar
inswva
Default Best route planning tools?
I'm going to be doing a solo ride in late April from southern Virginia up to Vermont/New Hampshire. My goal is eliminate/minimize any use of the interstate system, both there and back. I'll also be camping most nights with a motel/hotel thrown in a couple of times, either as a luxury or through necessity.
I've Google mapped a tentative route up there but it's been fairly laborious. I'll be going up through WV, PA, and NY and then cutting east through the Adirondacks before going through VT and NH; mainly on US and state routes. I haven't figured out the return leg yet. Before I spend more time banging around on Google maps, is there a better tool to use?
Old Mar 7, 2011 | 11:31 AM
piasspj's Avatar
piasspj
Can't beat good old fashioned Maps.
I particularly like the Atlases from DeLorme because they have all the back roads. Unfortunately for multi-state trips each state is a different book.
Old Mar 7, 2011 | 11:34 AM
wideglidebob's Avatar
wideglidebob
just point in out of your driveway and let it take you where it wants
Old Mar 7, 2011 | 11:41 AM
bigdaddy33's Avatar
bigdaddy33
Sounds like a great ride. I think there is a route planner on HD's site, but I pretty much use google maps.
BTW, Bring plenty of warm clothes. Still gets cold up north in April.
Old Mar 7, 2011 | 11:47 AM
krusty1's Avatar
krusty1
Microsoft's 'Streets and Trips' isn't bad...helps find motels, gas stations, bars, etc. Work out the trip, print it out, and take a few maps. My main goal is to find the secondary roads, and to stay off the interstates, if possible.
Old Mar 7, 2011 | 12:03 PM
rcaddell's Avatar
rcaddell
There is an avoid highways option on google maps.
Old Mar 7, 2011 | 12:31 PM
arcticharleyman's Avatar
arcticharleyman
Download Google Earth, much similar to Google Maps, but you can type in start point and destination, set layers for gas, food, malls, etc. I like it much better than Maps. You can zoom in and actually see all the roads, not just the main roads, cows in the fields and whatever. When you have finished setting your course, just print it out. It will also list the intersections to turn at and distances between turns.
Old Mar 7, 2011 | 01:12 PM
nevil's Avatar
nevil
Here's a couple of sites that may help you decide which roads to use:
http://www.motorcycleroads.us/
http://www.sundaymorningrides.com/
Old Mar 7, 2011 | 01:21 PM
Shrug's Avatar
Shrug
If you're not opposed to GPS, the Garmin Zumo has a feature to avoid highways. I'm using it to plan my Alaska route in June.
Old Mar 7, 2011 | 01:23 PM
Hockey Stick's Avatar
Hockey Stick
I find faults with each tool I use. One's good for this, but not that, One's fast and easy, the other is slow and hard to use, etc....
I end up useing 3 tools. MS Streets and trips, Google Maps, and the HD planner in combination with each other. And I extract/import routes and POIs from/to each other as much as possible. End up with 3 maps of a trip. But each is good for something.
